KZ750 H2 valve clearances
- lrburke
- bountyhunter
- Thank you received: 337
If it's an intake valve, it's probably OK. The exhaust valves get hotter and expand and contract more. The min spec on my 750 is .002", so .003" is no worries.I am working on checking the valve clearances on my 1981 KZ750H2. I have a service manual on it and the spec is .08mm-.18mm on both intake and exhaust valves. This means roughly .003-.007 in inches. I used the procedure that is in this factory manual and all of them are within spec but the number 2 intake valve is right on the bottom edge of this range! I can get a .003 feeler in it but it is tight but not to the point where you can't spin the bucket! Will this one valve require a cam removal in your guys opinion or will it be ok? Thanks for the help as usual!
- Nebr_Rex
- Thank you received: 300
Should be fine for a while.
Shimmed valvletrains don't go out of ajustment like the rocker arm set screw style does.
Sounds like a winter prodject.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- lrburke
- Motor Head
- Thank you received: 391
- JR
- Thank you received: 448
Black goo is not good.
Most of the guys here recommend Dyna coils but I cant remember which kind for the 750/4
Glad your valves are ok
- bountyhunter
- loudhvx
- Thank you received: 1616
You won't notice any symptom while on the highway because the vlave will only be leaking a very tiny bit. This timy bit will only affect idle.
So pay attention if you pull off a highway and come to a stop. If the bike stalls or the idle is rlow and rough, that may be the valve clearance.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- lrburke
- bountyhunter
