HOW MUCH OIL FOR KZ550?
- Hawk111
31 May 2010 10:55 #372313
by Hawk111
HOW MUCH OIL FOR KZ550? was created by Hawk111
I can't seem to locate in my manual how much oil is required for my 81 kz550. on the side of the tank it says 3 liters, but is that without or with changing the filter. If I change the oil filter is it more like 3.4 liters?
- loudhvx
- Thank you received: 1616
31 May 2010 11:22 - 31 May 2010 11:24 #372320
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic HOW MUCH OIL FOR KZ550?
With the filter change, I use more than 3, but not 4 quarts (liters are a little more than a quart, and Canadian quarts are different? Or was it Canadian gallons?).
JUst keep an eye on the sight window and check again right after running. You'll probably have to add a little more afer the initial startup.
Oh, and the sight window is only a valid level when the bike is turned off, and upright. When the oil is new, sometimes it's hard to tell where the level is. If you tilt the bike one way or the other you should see the oil level change. Make sure you have a good grip on the bike.
1981 KZ550 D1 gpz.
Other links.
Last edit: 31 May 2010 11:24 by loudhvx.
- Thank you received: 2098
31 May 2010 12:17 - 31 May 2010 12:18 #372343
by Patton
Replied by Patton on topic HOW MUCH OIL FOR KZ550?
Here's a little tip about viewing the sight glass.
Click > View sight glass while seated on bike
Last edit: 31 May 2010 12:18 by Patton.
