Clutch not engaging
- gte105u
30 May 2010 15:33 #372139
by gte105u
1981 KZ550 A2
Clutch not engaging was created by gte105u
Ok, so my bike and clutch was fine until I did something to it. I just got done with the chain/sprocket replacement. Got the rear wheel back on, adjusted, and it is off the stand. Now the clutch does not engage
I got the sprockets changed out yesterday and the chain fed. I noticed after I put the sprocket cover back on the clutch cable was too loose. I adjusted the cable and it is the perfect tension. Problem is that when I let the clutch out all the way it is not engaging. Could this be from me turning the adjustment knob under the cover? I really don't want to take the sprocket cover off again to play with the clutch if I don't have to. Please tell me there is an easy fix... I didn't even get into the engine so I think it should be.
1981 KZ550 A2
- hocbj23
- Visitor
30 May 2010 15:41 #372141
by hocbj23
Replied by hocbj23 on topic Clutch not engaging
u should have a small plate with 2 screws on the outside of ur sprocket cover.U should be able to take this plate off and adjust ur clutch.Dont know what kind of bike u have however.bj
- gte105u
30 May 2010 15:47 #372144
by gte105u
1981 KZ550 A2
Replied by gte105u on topic Clutch not engaging
I was thinking, hoping that's all that was.
1981 KZ550 A2
