Detuned KZ1000P's
- northrider
Detuned KZ1000P's
30 May 2010 09:57
I have purchased a 93 kz1000p, the bike runs good but I am the kind of guy that is always trying to make something a little better. I had heard the company detuned the kz1000p for safety reasons (is this true ?) and if it is true is there a way to fix this? How did they de-tune it?
- muddy1
- 1980 Kz1000 LTD B4
Re: Detuned KZ1000P's
30 May 2010 10:42
I beleive the compression was lowered on the Police bikes.
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- otakar
30 May 2010 11:56
Not true. Actually the carburetors were set up for more performance not less.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Zthou1977
31 May 2010 02:21 - 31 May 2010 02:22
The only difference in the engine (not sure about the carbs) is in the camshafts. The Police model used the same as the KZ1000-K and -M models aka the LTD and CSR. Compared to the J-model they have less peak horsepower (92@8000rpm vs 102@8500rpm) and less peak torque (8.7kg-m @ 7000rpm vs 9.3 kg-m @ 7000rpm).
As these are all more set up for cruising, I suspect that although max torque is lower, it kicks in at lower rpm's. At least, I'd hope so since otherwise they'd throw away performance. And that would just be silly.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Last edit: 31 May 2010 02:22 by Zthou1977.
- northrider
31 May 2010 08:52
Does anybody have a legit source where this stuff may be written down?
- Zthou1977
01 Jun 2010 02:14
The Police supplement for the KZ1000/1100 manual. I have it somewhere, but would need to do a search expedition since I haven't used it for a long time. About the only useful information in there is the wiring diagram. Tonight I'll try to find it and check the info.
- otakar
01 Jun 2010 07:24 - 01 Jun 2010 07:29
This information is provided in the respective Kawasaki OE service manuals for each model bike. Zthou1977 is right, The K, M, P, bikes were set up for longer and more efficient cruising with lower end torque.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Jun 2010 07:29 by otakar.
- northrider
01 Jun 2010 08:38
I was hoping that they (kawasaki) had possibly just necked down the exhaust pipes a little, say the opposite of a good set of headers.Then the cure would be an easy fix, a good set of headers! But I suppose the cam that is in the thing may give it a longer range, it needs all the range it can get. It keeps up with any v-twin on the road anyway.
Since I am the third owner ( chp, some other guy then me) I dont have a manual for the bike. But I did find a couple of wiring diagrams online and they really saved my ass. If it's a lot of trouble Zthou, dont bother looking for the manual. the bike runs great for this summer and all my mod's are going to take place this winter in the garage. All I have done so far is one: lexxan windshield, two: metalflake black paint job, three: rear seat that folds up for cargo and a back-rest.
this winter: new swing arm-fat rear wheel, four into one.
- Zthou1977
02 Jun 2010 02:36
Northrider,
That Police supplement has gone into hiding, couldn't find it anywhere. But just dropping in a set of J-cams should give you quite a bit more top-end.
BTW: what kind of fuel mileage are you getting? Mine does about 17 km/liter, but I am hoping this will improve after the overhaul I am doing.
- northrider
02 Jun 2010 07:04
I think its running about 40+ mpg, which is ok. they really should have engineered more volume in that tank though.
- APE Jay
02 Jun 2010 08:25
It may be the wat that the different departments ordered them, but when we did machine work for Glendale, Ca. PD, the head mechanic is a racing crew chief and he said the carbs had the slides drilled so they wouldn't open all the way. They didn't want these guys getting into chases with these bikes that had all that crap bolted on them.
We did a lot of 1076 kits for them and the CHP.
- dblhdr
03 Jun 2010 17:59
Follow the link to a KZ1000 Police Motorcycle forum that has all the info you might want about your COP bike. Just ask and one of these guys will probably have the answer. They are as good as the guys on this forum. Heck they ride KZ's too.:woohoo:
autos.groups.yahoo.com/group/kz1000p/
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
