- Thank you received: 1
sprockets
- HOGEATER
- Been riding 2 wheels since 1965,
28 May 2010 14:40 #371680
by HOGEATER
sprockets was created by HOGEATER
What is the original sprockets sizes on a 78 KZ1000. I want to get less rpm at hiway speeds. I now turn a touch over 4k at 65mph.. Should I go larger in front or smaller in back??
- mart13
28 May 2010 14:47 #371682
by mart13
Replied by mart13 on topic sprockets
i'd go larger on the front
- otakar
28 May 2010 14:51 #371683
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic sprockets
I wouldn't touch it you will gain nothing and loose everything if. At 4000 you are at the first peek on the torque curve and you are on the flat spot of the fuel consumption curve. But if you drop RPM even by 500 revs you will loose 10Hp and about 2 Lb/Ft of torque. This at no gain in fuel economy.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JMKZHI
- Thank you received: 48
28 May 2010 17:49 #371723
by JMKZHI
Replied by JMKZHI on topic sprockets
HOGEATER wrote:
The diagrams at Kawasaki.com will have the sprocket sizes, as well as other info for your bike... the cross-reference is a handy feature... for future reference.What is the original sprockets sizes on a 78 KZ1000...
- otakar
28 May 2010 18:03 #371728
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
In 1978 there were 3 different KZ1000s, Z1R, LTD & standard model. They all had different final drive ratios. Have to have more info than 78 KZ1000 to answer your question.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- z1kzonly
- Thank you received: 540
28 May 2010 19:01 #371746
by z1kzonly
Replied by z1kzonly on topic sprockets
15 front and 33 rear. For the KZ1000.
I am sure power or fuel does not matter to you.
Just lowering RPM's
Put a 16 tooth countershaft on the front. They are on ebay alot. If your chain is tight you might have to add a link.
Just lowering RPM's
- davel
28 May 2010 23:25 #371790
by davel
Replied by davel on topic sprockets
HOGEATER wrote:
Here's a 16T front
www.z1enterprises.com/detail.aspx?ID=2099
a source for aluminum back sprockets down to 30T
www.sprocketspecialists.com/SearchResults.aspx?txtSearch=276
and a really useful final drive calculator
www.gearingcommander.com/
Here's a 16T front
- HOGEATER
29 May 2010 04:07 #371802
by HOGEATER
Replied by HOGEATER on topic sprockets
OH I forgot to say it was a LTD model, I know when I'm running 80mph it don't take much to go over a ton. I just always seem to try to get another around 70mph.
CHUCK
CHUCK
- otakar
29 May 2010 04:35 #371804
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
If you must, than I do agree. I would go to a 16T front. This way you wont have to change the chain and you will go from a 2.2:1 ratio to a 2.06:1 ratio. That is significant.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
29 May 2010 04:37 #371805
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The 16t front will drop the RPM by about 250revs at 65MPH.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
