OIL COOLER
- catahe
28 May 2010 00:46 #371579
by catahe
OIL COOLER was created by catahe
HELLO RIDERS I OWN A KZ1000 Z1R AND I DONT KNOW WHAT TO DO HELP ME OUT WITH MY DECISION PLEASE.
MY BIKE HAS ONLY 8000 KILOMETERS (JAP VERSION)DO I REALLY! REALLY! NEED THE OILCOOLER I LIVE IN CANCUN MEXICO.THE WEATHER IS LIKE IN MIAMI SHOULD I? OR NOT. AND IF I DO WICH ONE IS THE BEST FOR IT THANKS 4 YOUR HELP
- H1Vindicator
- Thank you received: 51
28 May 2010 04:34 - 21 Feb 2013 01:58 #371596
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 21 Feb 2013 01:58 by H1Vindicator.
- hugo
- '92 Zephyr 750
- Thank you received: 71
28 May 2010 04:52 - 28 May 2010 04:57 #371598
by hugo
Replied by hugo on topic OIL COOLER
You don't really need it, but is better to have because it keeps the oil temp in check, if bike is ridden hard. It will contribuite to engine longevity. The oil cooler itself is not much of a problem, but it is how to connect it to the oil circuit.
I have a 750 that came from factory with the oil cooler lines in the oil pan, but am not sure on the 900/1000/1100 motors. Am sure you'll have plenty of suggestions from owners.
Last edit: 28 May 2010 04:57 by hugo.
- otakar
28 May 2010 05:21 - 28 May 2010 05:21 #371601
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic OIL COOLER
I had my Z1R in Hawaii for 3 years and never had a need for it. Only after I bored it out to 1105cc did it start getting hot. Even than the oil cooler was not necessary. Run a good motorcycle oil or a good Diesel truck oil, like Shell Rotella-T and you will not have any problems, especially if it is stock.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 May 2010 05:21 by otakar.
