add kiker to 1980 750e
- arldavey
27 May 2010 21:40 #371562
by arldavey
add kiker to 1980 750e was created by arldavey
I have a case and guts from a 78 650 could I use them to add a kick start to a 80 750e motor?
- otakar
28 May 2010 05:30 - 28 May 2010 05:30 #371604
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic add kiker to 1980 750e
Sure, just build a 750 motor on top of a 650 transmission. As long as you have all the internals for the kick start. It will take some machining to install the 750 top end onto the 650 case though. it will be a lot of work and money just for a kick start.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 May 2010 05:30 by otakar.
- arldavey
28 May 2010 13:13 #371670
by arldavey
Replied by arldavey on topic add kiker to 1980 750e
oh I can feel the starter clutch calling me
- otakar
28 May 2010 14:55 #371686
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
It'l be much cheaper and about 2% of the work to change the starter clutch.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- steell
30 May 2010 16:46 #372159
by steell
Replied by steell on topic add kiker to 1980 750e
Just take the kickstart parts off the 650 and install them on the 750, all the provisions are there.
I have a 750 four bottom end with a kickstarter.
- JR
- Thank you received: 448
30 May 2010 17:47 #372170
by JR
Replied by JR on topic add kiker to 1980 750e
Nice to see you back steell
