cam chain tensioner spring
- brianrae33
27 May 2010 08:36 #371344
by brianrae33
1982 kz1000ltd
cam chain tensioner spring was created by brianrae33
anyone know where i could find a cam chain tensioner spring for a 1982 kz1000? hardware store maybe??
1982 kz1000ltd
- wes_scooter
27 May 2010 08:46 #371346
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic cam chain tensioner spring
try ebay. or get a manual adjuster and save the troubles. a spring from the hardware store might work but you wont know what tension spring is correct.
76' kz900
70' yamaha R5
2006 wr450f
- otakar
27 May 2010 08:55 - 27 May 2010 08:56 #371347
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic cam chain tensioner spring
If you replace the spring and not the entire adjuster with a manual APE one, get a NEW OEM Kawasaki spring. You can get that threw Z1E. If you put the wrong tension spring in there you can do a lot of damage. Make sure that you replace both the springs in the tensioner. Those springs are critical and they go bad with age and heat.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 27 May 2010 08:56 by otakar.
