Name That Part!!!!
- Fozzie
26 May 2010 19:22 #371223
by Fozzie
1982 KZ1000J
Name That Part!!!! was created by Fozzie
So I got another Noobzilla of a question. What is this plug nut looking thing on top of the engine next to the plug and why is it leaking oil? Can I tighten it?
1982 KZ1000J
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 May 2010 19:30 - 26 May 2010 19:31 #371226
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Name That Part!!!!
Its a nut.
Yes you can tighten it.
It is one of 12 nuts, plus two small bolts (just below the outside plug holes) on your cylinder head.
These nuts actually keep the entire engine intact.
The outside nuts have copper washers under them because they seal the oil channel beneath.
In order to reseal these, you must first re-anneal the copper washers, which means heat them up super hot with a torch, then toss them into some nice cool water. This softens the copper molecules and allows them to reseal.
The head nuts must all be tightened in proper sequence outlined in your service/repair manual.
They are usually tightened to about 30 ft-lbs.
A proper torque wrench is required.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 26 May 2010 19:31 by TeK9iNe.
- PLUMMEN
- Thank you received: 104
26 May 2010 19:34 #371228
by PLUMMEN
Replied by PLUMMEN on topic Name That Part!!!!
looks more like the valvecover gasket and cam end plugs are leaking ,though it wouldnt hurt to retorque the head
- Fozzie
26 May 2010 19:47 #371239
by Fozzie
1982 KZ1000J
Replied by Fozzie on topic Name That Part!!!!
Arite, thanks man! With your awesome knowledge of all my noobalicious problems this bike is gonna be tip top shape.
1982 KZ1000J
- 550A2
- keep the shiny side up
26 May 2010 22:18 - 26 May 2010 22:20 #371270
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic Name That Part!!!!
i think you need a gasket kit man! if one gasket fails, the others arent far behind it, if they were installed at the same time.
base gasket
head gasket
valve cover gasket
cam seals...
good hot and cold torque. as technine said, SEQUENCE. sequence is very important when torquing gasketed parts.
By seeing that i would do it in a heartbeat, (just my opinion)...unless all your head bolts/nuts are looser then a hookers cooch.
-Luke
base gasket
head gasket
valve cover gasket
cam seals...
-Luke
Last edit: 26 May 2010 22:20 by 550A2.
- H1Vindicator
- Thank you received: 51
27 May 2010 06:06 - 20 Feb 2013 20:24 #371301
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:24 by H1Vindicator.
- Old Man Rock
- Thank you received: 225
27 May 2010 06:50 #371310
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Name That Part!!!!
Is the oil coming form around the front side?
You have an image of the front and side but lower/parallel to the oil leak?
As Plum mentioned, hard to say though for sure, seems the oil is rising up from the cylinder stud nut... May just be the angles of the image...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 1981jmotor
- shade tree mechanic
27 May 2010 07:34 #371329
by 1981jmotor
1981 Kawasaki CSR 1000
First bike ever at 14 years old was 1969 Honda CL 175.
Bought a brand new Honda CM400T at 16 years old in 1979.
Replied by 1981jmotor on topic Name That Part!!!!
Fozzie, I have the same J motor you do. It looks like you cam end caps are leaking.
My reccomendation depends on how much time and money you have and your skill level. If you are like me, and are on a time and money budget, do the following:
remove tank, ign coils w/brackets, #1 and #4 spark plugs(the outer ones), and finally the cam cover. If you do not have a new cam cover gasket, then after you remove all the bolts, if the cover is not loose, carefully bump it with the wooded handle of a hammer. When you see it is loose, carefully lift it up about a quarter of an inch. More the likely the gasket will be sticking to both the cover and the head. Take some kind of thin metal tool like and exacto knife, or you better half's butter knife, and while holding the cover up a little, reach in and separate the casket from the cover. Then remove the cam cover.
Remove the cam end caps by pulling straight up on them.
Now degrease the gasket, and gasket surfaces on both the head and cam cover, and the cam caps.
Get some high heat silicome, and coat the head surface, the bottom and top of the cam caps, and the cam cover. Before you put the cover on, be sure to retorque you head bolt nuts, and the 2 10mm bolts on the ends.
Factory torque is about 30 ft lbs- I went a little more on mine.
Be careful that you put the gasket on the right way. I put mine on backwards the first time because it has 2 holes on the front side for the smog valve ports that pump air down to the exhaust valves.
Good luck with this quick, and cheap fix.
David
David
- 1981jmotor
27 May 2010 11:50 #371388
by 1981jmotor
Just some additional notes....
Unless you want your bike all original, you can remove the smog valve and chuck it at the neighbor's dog that keeps chasing you as you ride by.
Remove the hose going to the airbox, and plug the hole. For looks, get some 5/8" heater hose, and connect the 2 nipples on top of the cam cover together without hose clamps.
You can get rid of the vacuum line that went to the smog valve. Just block the nipple it went to. THe only vacuum line on mine is one going to the fuel petcock from one carb.
The following make great degreasers- brake cleaner, starting fluid, and carb cleaner. Just lay your old cam cover gasket on a piece of clean cardboard, spray it with on of the above chemicals, and wipe it with a snot rag, paper towel, etc.
What I like about this forum is that other members who have done this job more than I have can contribute and we all learn more as we go- even if we argue sometimes.
I agree with Plummen's reply below, or above?
- patmann
- Thank you received: 6
27 May 2010 11:58 #371390
by patmann
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Replied by patmann on topic Name That Part!!!!
Clean the whole area THOROUGHLY, as in NO OIL. THEN sprinkle a small amout of baby power ( if needed ) , ride a short distance and observe for oil leakage.
Yes I do understand the power will blow off. But many times it leaves just enough residue to show where the oil leak is coming from. NOT to where it travels to. IF you only do a short ride.
Best of luck!
Pat
Best of luck!
Pat
