Air Shifter.....few ???'s
- iroc355
26 May 2010 16:29 #371156
by iroc355
Air Shifter.....few ???'s was created by iroc355
so im looking to get my air shifter in the next few days. im looking at the MRE shifters and i see there is a junior and a deluxe. My bike is going to be a 1200, mild compression undercut trans. Just wondering if I need the deluxe or if the junior will cut it for me.
thanks in advance
thanks in advance
- timebomb33
- Thank you received: 10
27 May 2010 16:52 #371464
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Air Shifter.....few ???'s
go for the deluxe system it has the proper dot 1800 psi. tank and a bigger air ram.
- iroc355
28 May 2010 15:10 #371691
by iroc355
Replied by iroc355 on topic Air Shifter.....few ???'s
thing is i'm running an air tank in my swingarm, so a DOT tank isn't a huge deal at this time. I'm not planning on going any bigger for a few years so if a junior will work for me that saves me over $100 plus every ounce of weight counts!
- timebomb33
28 May 2010 17:10 #371716
by timebomb33
then go for the junior for sure forgot you were using an inframe tank. and believe it or not you can buy air rams that are very good quality from princess auto. very reasonably priced as well i use them on my big bike.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
28 May 2010 22:56 #371789
by Skyman
West Linn, OR
Replied by Skyman on topic Air Shifter.....few ???'s
FYI
FYI
West Linn, OR
- iroc355
29 May 2010 05:58 #371814
by iroc355
thanks for the heads up
- timebomb33
29 May 2010 07:35 #371834
by timebomb33
the one on e-bay that is used is more money than the ones from princess also they are rebuildable they have seal kits for them. plus all the legris air fittings and adaptors you will need and even 1/4 inch air line in rolls. 20 mm bore cylinders 2" stroke are $15.99 part number 8188179 and stainless body 2" stroke 25 mm bore cylinders are $25.99 pn. 8246886
