clutch plates sticking together
- wes_scooter
26 May 2010 13:46 #371124
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
clutch plates sticking together was created by wes_scooter
after a few days of sitting, the kz900 that i brought back to life after 20 years has clutch plates that stick together and when i try to put it into gear it stalls it. i go through the oil fill plug hole and free up the inside 3 plates and it works after that. will that sticking go away with some use or will i have to diss assemble it and repair the clutch.
76' kz900
70' yamaha R5
2006 wr450f
- Thank you received: 2098
26 May 2010 14:01 #371127
by Patton
Replied by Patton on topic clutch plates sticking together
wes_scooter wrote:
Could perform clutch pushrod adjustment
Perhaps gap is too large, so that clutch isn't fully disengaging when handlebar clutch lever is squeezed.
- otakar
26 May 2010 14:15 - 26 May 2010 14:16 #371131
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic clutch plates sticking together
It is very likely that you have an old stile Barnett Cork clutch. That is exactly what they did if thy sat for more than a few days. I had the same problem on my Z1R when I installed a Barnett clutch way back when. The only thing that could be done is to replace it with a NON- Cork clutch, which is any clutch made today or an OEM clutch that you can find on eBay.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 May 2010 14:16 by otakar.
