KZ1000 Stator Covers
- Rick_R
26 May 2010 12:18 #371083
by Rick_R
KZ1000 Stator Covers was created by Rick_R
Hi Guys,
Hey I need to replace a stator cover on a 1980 KZ1000 E2 model and was wondering what covers will fit.
My parts fiche states that the part number for my cover is 14031-1015 & cross referenced it fits the following models:
A3 - A3A - A4
B4
C3 - C4
D3
E1 - E2
I am having a difficult time finding a cover that doesn't cost and arm and a leg, does anyone know if a 79 (B3)cover will fit? I have found one that is reasonably priced and is located in my area and was wondering what the differences in this cover could be since my parts fiche states that it wont fit.
I would appreciate any input form some of you that have had experience swapping stator covers on these bikes.
Thanks,
Rick
A3 - A3A - A4
B4
C3 - C4
D3
E1 - E2
Thanks,
Rick
- mark1122
- Keep twisting it
- Thank you received: 109
26 May 2010 13:09 #371114
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic KZ1000 Stator Covers
If u can see a pic of the cover it should be obvious. some correct me if i'm wrong .
the 73 to 78 Z1 KZ covers look the same and are interchangable.
the 79, 80 covers should all be the same in aperance, but very dif than previous covers.then came the J's then GPZ.
So your 80(and 79's) will look dif than the other models. if u find 1 that looks like yours, it will fit.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Jack
- Thank you received: 7
26 May 2010 13:20 #371118
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic KZ1000 Stator Covers
79 B3 LTD's don't have a MKll engine- that's why the stator covers won't fit your E model shaft drive.Different crankshaft ends and stators.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- otakar
26 May 2010 14:24 #371133
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic KZ1000 Stator Covers
You must use a MKII or an ST engine cover. The earlier engines had a completely different alternator unit and will not work and the "J" series engine that actually did have the same stator will not work either. But the latter I am not 100% sure about. See if the stator for the "J" and the MKII are the same if they are you might have a chance with a "J" cover.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Rick_R
26 May 2010 16:24 #371155
by Rick_R
Replied by Rick_R on topic KZ1000 Stator Covers
Thank you all for your replies. Both Jack and otakar what you state does make it clear to me now. I have located a cover from a "1980 Police Bike C3" that should work according to my parts fiche. What do you think?
- roy-b-boy-b
- Thank you received: 103
26 May 2010 17:36 - 26 May 2010 17:36 #371177
by roy-b-boy-b
Replied by roy-b-boy-b on topic KZ1000 Stator Covers
Last edit: 26 May 2010 17:36 by roy-b-boy-b.
- otakar
26 May 2010 18:09 #371189
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
That answered that question, because that is definitely a "J" cover. This also poses an interesting option. If a MKII or "J" rotor can be mounted on a KZ900/1000 Crank Shaft than a 20A alternator could be mounted on an earlier 73-78 bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
26 May 2010 18:24 - 26 May 2010 18:25 #371199
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ1000 Stator Covers
j cranks and mk11 cranks have a 25 mm end and early models from 73 to 78 and some 79's have a 22 mm end on the rotor side which they won't interchange. speaking of which does anybody have a 22 mm remote starter nut for sale.
Last edit: 26 May 2010 18:25 by timebomb33.
