- Thank you received: 25
turbo charger for my kz650
- T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- DoubleDub
- Visitor
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- steell
Or, if you really want a cool project, my nephew has a 650 (77 I believe, SBJones for anyone that remembers) with GSXR 1000 usd forks, swingarm (monoshock) and wheels, and a good 750 Turbo motor without the turbo or throttle bodies. Make a heck of a combination for someone, since he's never going to get around to it.
For contact info PM me on 750turbo.com, or here but I don't stop in here very often.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- DoubleDub
- Visitor
Do it the easy way, spend $2500 or so for a 750 Turbo and scare yourself silly, it's fun!
Now where's the fun in all that! I agree, that's probably the most cost effective way to do it....but that throws the creative process out the window :silly:
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- GPzephyr
The hard way to serious power could be damn expensive. Exhaust manifolds, plenum chambers, Turbo, Rods, Pistons, Lock-up clutch, fuelling, oil scavenging. Its not easy at all.
On a more basic budget you could prob do it using standard rods and pistons. just limit boost to no more than 10psi. will get ya about 100-110bhp max, then you could also use stock clutch with heavy springs etc. Mount turbo as high as possible (above oil level) then use gravity to drain oil back to sump instead of using a scavenge pump system. Use BS34 carbs and pressurise the float bowls to get some sort of basic fuelling. Pick up a turbo off ebay such as a Garrett T20 for not much money but you would still have to make up a suitable manifold/headers for it.
It would work but be quite limited.
Using the GPz engine as a base is so much better. Kawasaki made a lot of subtle improvements to it to make it work well as a turbo engine.
There are bikes on the 750 turbo forum putting out close to 280hp at the tyre using standard rods, crank and cases.
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- DoubleDub
- Visitor
1. Learning opportunity
2. The DIY factor (or is that the idiot factor?)
Anyways, good points all around!
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
