- Thank you received: 1
Vacuum problem still there! Hopeless!
- polkat
>>While stuck at the too high idle, what is effect of adding some choke?
Full choke will lower the rev just a tiny bit. Kills the engine at idle.
>>If carbs are like the image shown below, which is the "hidden" pilot air jet referred to?
Not seen in that pic. Here it is...
It is item #10 in the pic.
Fooled around with it today. Literally flooded the carb holders and carbs with WD40 as it idled. No change-no smoke. Tried the same as it revved-same result. I have discovered that if I leave it revving high as it does, it eventually comes down on it's own. Takes maybe 10 seconds.
Now, this peaked my interest! As it starts to come down, there is a click or tick or clack, then it comes down. Almost as if someting hung up is letting go before it can come down to idle. Unfortunately, it has a loud exhaust and I can't quite tell where this noise is coming from. Can....well, can a butterfly still be open if the linkage is closed? Can it hang up on something and not follow the linkage? I know that some car carb butterflys are spring loaded to the linkage. Or could the symptoms becaused by a hanging slider?
- Motor Head
- Thank you received: 391
Battle on.
- polkat
Phone rang, and while talking I started turning the (now free) throttle cable back and forth at the grip. It had been my assumption that the throttle cable was snapping back to full closed when I released it as it revved. It both sounded and looked like it was fully closing, and I still mostly believe that.
But, while free from the carbs, I noticed that the cable hangs up, slightly, at about the halfway point in it's travel (hummm...just about at the point where the rev takes over). I can force it through this hangup easily with the grip, but if I try to pull it through with the little ball on the other end, it's a little bit difficult.
It's hard for me to believe that the springs on the throttle shafts can't pull through this slight hangup, but at this point I'm considering everything! Opinions? Also, what's a good easy to find lube for the cable? Thanks!
- Old Man Rock
- Thank you received: 225
Reasoning, ideal operations, with no coke applied your vacuum would be ~ 20cmHg... If the vacuum is way down ~ 5-10cm, then your choke circuit is still in operation...
NOTE: I'm not saying you forgot about the choke lever, I'm meaning internally the choke circuit itself is whacky....
Just ran into this today where after warming up the engine, hooked up my gauges and as mentioned above way low... I was like WTF.... Then I realized the sucking sound with the tops off the carb was due to the choike still on.... DOH!
Yup, the coke lever was still on a tad. Switched off and my vacuum jumped right up where they out to be....
Just a thought... Maybe different on your setup/carbs...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2236
- Motor Head
- Thank you received: 2098
You may want to replace the cable as it may be frayed in the housing and could stick at WOT and scare the #&*^) out of you, and at the same time inspect/ lube the handle bar where the grip twists/ upper throttle cable guide.
Yes -- and new cables are relatively inexpensive, and available from Z1E.
Lubing is important, and the lube tool mentioned is excellent, but lubing won't help an internally frayed cable.
Good Luck!
- polkat
Turns much more freely now without the centuralized hangup I mentioned earlier. Still, it's not as free as would be fully desired, but I have verified that (without the engine running at least), it snaps back to idle quite strongly.
Nothing was done with the carbs this time (as I saw nothing to do), except I backed all the pilot screws out another 1/2 turn (total of 2-1/2 turns out on all of them).
I will put it all back together tomorrow, then crank it up and see what happens.
- stonemaster
- Visitor
- Capt America
- Born Bad
I know it's a hard reach especially on a 4 cylinder with the air box in, but can you not just (eliminate the cable from suspect) by not hooking it up, and reach in and flip the throttle open by hand a few times to see if it returns to idle properly.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
