Clutch slipping
- rnuse
- Balls to the walls, sideways all the time
For an almost 30 yr old bike and 12,000 miles am I ready for clutch springs? Or all new clutch parts?
Thanks everyone
1982 kz750 ltd
Drag bars, 4into1 V&H with no baffle.
1991 zephyr 550
about to give up on her.
- otakar
kzrider.com/index.php?option=com_kunena&...cribed+to+this+topic .
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
So my '82 kz750 has 12,000 miles. After searching on here I'm thinking it's the clutch springs. I have already tried adjusting the clutch. Counter-clockwise until snug right?
Thanks everyone
...already tried adjusting the clutch. Counter-clockwise until snug right?
But then supposed to turn clockwise 1/2 turn before tightening locknut. This creates the necessary gap between adjuster screw and push rod. If not done, the clutch will slip because can't fully engage absence the gap.
- otakar
Thanks everyone
I agree. Besides that, you can friction WELD the pusher rod to the pusher and blow out the side cover.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Bluemeanie
- Thank you received: 14
Maybe my 650 is different but mine is adjusted clockwise until snug then back off 1/2 turn. Then without changing adjustment you tightend nut.
- otakar
I just hate tight nuts, Don't you? :ohmy: :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- rnuse
1982 kz750 ltd
1991 zephyr 550
Slide type --- as on Z1 and KZ900 and KZ1000 to engine #KZT00AE025468.
Ball type beginning on engine ##KZT00AE025468.
Clearly the slide type is adjusted by screwing in clockwise until snug, then out counterclockwise 1/2 turn.
To me, it isn't so clear about the ball type adjuster.
The FSM, when speaking of the conversion to ball type, refers adjustment procedure to earlier instructions about the screw type.
However, in actual practice, the ball type is reportedly adjusted by screwing out counterclockwise until snug, then in clockwise 1/2 turn (opposite of screw type).
Which to me seems counter-intuitive.
Perhaps someone who's positively certain about which way to turn the screw when adjusting the ball type will post confirmation as to whether it's the same or opposite the screw type.
Regardless, on ball type, whichever way to turn the adjusting screw should be apparent when performing the adjustment (just notice reaction to clutch handlebar lever when squeezed and released). The objective is to lightly snug the fit so as to close the gap (by first turning screw whichever way is necessary to accomplish this), and then loosen the screw 1/2 turn to create the gap.
Loosening instead of snugging will cause more slop in cable play at the handlebar lever.
- Thank you received: 2829
- Link14
- Thank you received: 6
Good luck!
