- Thank you received: 10
1981 KZ1000LTD misfiring?
- timebomb33
I THINK MY POWERBAND BROKE
- Kawickrice
- Thank you received: 18
I am having to remember back about 2.5 yrs on this, but I think the following is a description of the flywheel puller.
The flywheel has some threads in its central hole. The puller is like 2 tubes, one threaded inside the other. The outer tube has threads on the end that thread into the flywheel. The inner tube is turned, pressing against the end of the crankshaft, and drawing the outer tube, and flywheel with it.
my 2 cents. I am no guru, but I do not see how the top triple tree nut could work as a substitute for this puller. Maybe they changed the design from the earlier bikes.
No offense or argument intended.:woohoo:
Once again this works for the early motors not sure about the J motor.
The large Bolt on the triple tree will thread into the rotor. The manual says to drop a large ball bearing into the hole and will sit on the crank snout as the screw threads in it bottoms out on the bearing and pulls the rotor.
This is a factory design and is mentioned in one of my manuals. It works like a charm. Sounds to easy I know but those Japs can be pretty smart engineers sometimes.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 1981jmotor
- shade tree mechanic
Timothy, I must respectfully disagree with what Timebomb posted below about "the noise you are hearing is most likely the carbs being out of sync". I base this on the fact that I heard your bike in the video making the same noise mine did when it had the loose 'starter clutch to rotor' bolts. I would it bet it mainly does it at idle, and it may sound funny when it is cranking. I do not think that a rattle from the shifter side of the bike would be caused by carb sync issues.
Also, forget what I wrote earlier about having to remove the footpeg, and the shifter. That is for pulling the cover for the final drive sprocket.
1981 Kawasaki CSR 1000
First bike ever at 14 years old was 1969 Honda CL 175.
Bought a brand new Honda CM400T at 16 years old in 1979.
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
