Base gasket replacement
- oppie501
28 May 2010 16:43 #371707
by oppie501
Replied by oppie501 on topic Base gasket replacement
Just went through this on my build. Harbor frieght sells i believe a five pack of different width plastic scrapers. They are shaped like wood chisels, and are extremely sharp. They get under the old gasket, and since they are plastic no worries of gouging the aluminum. 5 pack sells for around 10 bucks. Best 10 bucks i ever spent. Good luck.
- Motor Head
- Thank you received: 391
28 May 2010 17:01 #371712
by Motor Head
Replied by Motor Head on topic Base gasket replacement
Glad to here you finally got it all off, don't worry to much about the small pieces going into the crankcase, do a oil + filter change and there they'll be.
- keith1
- Thank you received: 2
28 May 2010 17:05 #371715
by keith1
Replied by keith1 on topic Base gasket replacement
Motor Head wrote:
better yet...pull the pan..tit job and get all the crap out of there.....you would be surprised to see the nuggets in a 30 year old pan.....
- fordtruck
- Thank you received: 6
28 May 2010 22:40 #371786
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Replied by fordtruck on topic Base gasket replacement
better yet...pull the pan..tit job and get all the crap out of there.....you would be surprised to see the nuggets in a 30 year old pan.....[/quote]
I second that. I pulled my oil pan and couldn't believe the crud that was in it.
