Base gasket replacement
- chrispysaki
So I was thinking about just putting the new gasket over the old one, which is squished really flat to begin with. Is this a terrible idea? Is there an easier way to get the gasket loose?
Thanks,
Chris
- Motor Head
- Thank you received: 391
- chrispysaki
- Jodyb17
1977 KZ 650 C
- bountyhunter
- Thank you received: 337
Absolutely horrible, don't even think about it.So I was thinking about just putting the new gasket over the old one, which is squished really flat to begin with. Is this a terrible idea?
chrispysaki wrote:
you can soften it with brake fluid. The factory seals that gasket with super glue like 3 bond (I already went through this). Pack shop rags in to prevent the stuff from falling down. Use a single sided razor, hold it straight up to scrape it. Go slow, figure on spending a couple of hours. vacuum the crud up after a little bit and work around.I have the jugs off and want to put a new base gasket on, but the old one is really stuck to the case. I tried scraping it with a steel chisel, but there's no way I would be able to get it off without damaging the aluminum.
- bountyhunter
That works on gasket material but my base gasket was held on with permanent sealer similar to three bond. You have to scrape it off.Go get a spray can of Gasket Remover at the Parts store, it will eat it off quite easily.
- Buda
I just went threw this and bountyhunter is rite. I tryed the gasket remover and it softened the gasket a little,mostly scrapeing is what got mine off. Alot of scrapeing. :blink:Motor Head wrote:
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- chrispysaki
- Jodyb17
1977 KZ 650 C
- hocbj23
- Visitor
- bountyhunter
After you get the stuff scraped off, I recommend going over the surface with scotchbrite pad and then wiping with acetone. It will be super clean then.
I used a thin bead of black sealer on my base gasket. 3-bond or similar is good. It makes it harder to remove but you hardly ever change that gasket, and it will absolutely never leak..
- chrispysaki
I did get a couple small schnibbles of the gasket into the crank case - will that cause problems later on? I'm not sure how I'd get them out.
