81 KZ440 Leaking Oil Pressure Switch
- gaillarry
23 May 2010 15:58
My buddys' KZ440 developed an oil leak from the top of the oil pressure switch. Is it necessary to get a Kawi replacment or is there an aftermarket part available?
1977 KZ1000
1985 Gpz750
1985 Gpz750
- MFolks
Re: 81 KZ440 Leaking Oil Pressure Switch
23 May 2010 16:27
I'd try the dealer first,
www.z1enterprises.com
next, remove the switch and see if a car part would fit/work.
What oil pressure are you talking about?
- gaillarry
23 May 2010 16:48
With the engine running oil is flowing from the top of the switch. I'll try an auto parts supplier they may have one to match it.
1977 KZ1000
1985 Gpz750
1985 Gpz750
- MFolks
23 May 2010 16:57
The oil pressure switch may have the pressure stamped/printed on it, also check the threads for compatability.
- LBKJUGGALO
11 Jul 2012 00:24
Did ya ever get this figured out? My 1980 440 just did this to me.
11 Jul 2012 08:39
No eBay APP ID and/or Cert ID defined in Kunena configurationIf mine I would just bite the bullet and buy a new old stock one.
The following user(s) said Thank You: LBKJUGGALO
