KZ 1100 Won't start... except rarely
- rbdancer
In my sporadic efforts to get it going over the past few months, I have had it start up from cold exactly twice. Each of those two times it then ran normally, and I was able to make a 12-mile round-trip for gasoline and a shakedown run. The bike ran exactly as it should. It was a completely normal ride, with nary a hiccup.
The second time this happened was a few days ago, right after I had replaced the spark plugs, re-secured the spark plug wires, checked and cleaned the air filter element, and drained the carburetor bowls. Since then, I have also checked both ignition coils and the secondary leads with an ohmmeter, and they are well within spec.
In the fire triangle of needs for combustion, I'm pretty sure fuel is moving through the system as it's supposed to, and nothing is blocking the air intake, so that seems to leave me with spark. If it's not the ignition coils or the plugs, what remaining culprits can I look for?
- hocbj23
- Visitor
- MFolks
- Thank you received: 540
If that's not it, try this test:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of X 100 check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S†electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
Kawasaki part # 59026-1133 is the pick up coil you might need. They list for $139.05 but if you become a forum member at www.kawasakimotorcycle.org the price is $118.19
- fordtruck
- Thank you received: 6
'77 KZ1000-MTC 1075 kit. Stage 1 port
- hocbj23
- Visitor
- rbdancer
I did inspect the (very clean) fuel screen on the fuel tap assembly, and I have now also checked the resistance of the pickup coil (right in the center of the tolerance range) and the vacuum reed valve (working correctly). I've also been inspecting and re-connecting all the electrical bits when I run across them.
I'm going to check the valve clearances next, a task I've never attempted, but this one has been full of firsts. I do appreciate all the suggestions. I'll post anything I find out.
Many thanks,
RB
- Thank you received: 2098
...1982 KZ1100...unable to start the bike the next morning...right after...I drained the carburetor bowls...pretty sure fuel is moving through the system as it's supposed to....
Where carbs have been drained, before attempting to start the engine, petcock should be turned to PRI for a few moments (up to 30 seconds, maybe longer) in order to allow the dry empty carb float bowls to fill.
Assure kill switch in RUN position, apply full choke, DON'T TOUCH THROTTLE, and then attempt to start engine. Remember to not touch the throttle while cranking.
- Motor Head
- Thank you received: 391
As far as not starting, check your voltage reaching the coils while cranking, and make sure that Ignition switch is not a bad connection/ high resistance problem. Moisture can get into the contacts over the years.
Have you ever fully cleaned the carbs out? Or kitted them? If not this way over due.
- rbdancer
It looks from my Clymer manual that I might also need a special Kawasaki valve lifter holding tool. If the shop doesn't carry that, is there a workaround for holding the lifter in place while replacing the shim?
BTW, I did a complete tear-down and cleaning of the carburetors about 2,500 miles ago, and installed new-old-stock carb boots at that time. That's the one part of the system I feel pretty good about. I appreciate the heads-up, though.
Thanks to all,
RB
- Motor Head
Don't forget to Sync those carbs when done, there are some how to make a sync tool in this forum, including a write up I did.
So it looks like the valves are indeed the culprit. Only three of the eight valves are anywhere close to having enough clearance. Now I guess I need to buy a micrometer, learn about replacing valve shims, and hope the Santa Fe Motor Sports dealer carries the shims.
For helpful articles on setting valve clearances with the Motion Pro tool ---
Click on the Search Forum box (see image below);
Type in batwing
Click on Go
Z1E carries shims.
Z1E also carries the Motion Pro tool and Factory tool:
Click > Motion Pro tool at Z1E
Click > Factory tool at Z1E
KZ over bucket shims are 29mm diameter.
KZ under bucket shims are 13mm diameter.
Usually shim size is marked on the shim itself, on the bottom side next to the bucket where it's protected from being rubbed off by the cam lobe.
Where shim size is illegible, a micrometer or decent caliper may be used to determine thickness of the shim.
As known, shim sizes are produced in increments of .05mm from 2.00mm through 3.15mm.
KZ large fours with over-bucket shims generally have FSM clearance specs of .05mm~.10mm on all valves, both intake and exhaust. Some knowledgeable folks allow up to .15mm clearance for exhaust valves.
[Click on image to enlarge view.]
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
