I need help with Crank bearing Question
- thompsonmx100
21 May 2010 19:29 - 23 May 2010 00:09 #369679
by thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
I need help with Crank bearing Question was created by thompsonmx100
I have found a set of cases for my gpz 750 finally.
I have heard of a marck on the crank bearings. I'm not sure if I need to use the set of bearings in the cases or the bearings that came out of the other set of cases that the crank came out of. Any help would be greatly appreciated.
1985 gpz750
Kz 650
Last edit: 23 May 2010 00:09 by thompsonmx100.
- thompsonmx100
22 May 2010 02:02 #369729
by thompsonmx100
1985 gpz750
Kz 650
Replied by thompsonmx100 on topic Crank bearing Question
Bump need some info on what the difference is between the bearings
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
- Thank you received: 109
22 May 2010 04:38 #369737
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Crank bearing Question
PM steel. he is up on this stuff. or try the kz650 forum.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thompsonmx100
22 May 2010 10:12 #369802
by thompsonmx100
1985 gpz750
Kz 650
Ha made ya look
1985 gpz750
Kz 650
- trianglelaguna
- Thank you received: 235
22 May 2010 15:15 #369874
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic chick needs help with Crank bearing Question
decent...upperdecker material for sure
1976 KZ900
2003 ZX12R
2007 FZ1000
- larrycavan
- Visitor
22 May 2010 17:39 #369903
by larrycavan
Replied by larrycavan on topic chick needs help with Crank bearing Question
thompsonmx100 wrote:
In situations like this, you absolutely must measure clearances. You cannot trust crank markings or case markings.
I would start with a set of bearings that you can actualy identify the color codes on. Use them in the cases you intend to build up with and plastiguage the clearances.
Plastiguage is available at any autoparts store and is very inexpensive.
If you don't measure the clearances, you're rolling the dice.
- thompsonmx100
23 May 2010 00:08 - 23 May 2010 00:10 #370036
by thompsonmx100
1985 gpz750
Kz 650
Replied by thompsonmx100 on topic chick needs help with Crank bearing Question
Good point Larry. I guess I need to run down to the auto parts store. Is the marking info in the manual somewhere? Does the manual discuss the different markings?
1985 gpz750
Kz 650
Last edit: 23 May 2010 00:10 by thompsonmx100.
