1000 bottom end finally coming together
20 May 2010 20:49 #369438 by jordan
Started putting my bottom end together tonight. Got the welded crank in, main cap on, HD 2nd gear on, and transmission in cases. Other than the kickstarter, what else needs to be assembled BEFORE bolting the cases together. I want to get the cases together, for now all the stuff that can be added on after will be done later
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • porchev914
20 May 2010 23:13 #369461 by porchev914
Replied by porchev914 on topic 1000 bottom end finally coming together
Good luck bud. I can't think of anything else you need just to join the cases....but if there is something, someone more experienced than myself will chime in :)
FRANKEN Z!
  • larrycavan
  • Visitor
21 May 2010 04:46 #369479 by larrycavan
Replied by larrycavan on topic 1000 bottom end finally coming together
Cam chain on the crank?
Proper O ring between the case halves?
  • mark1122
  • Keep twisting it
21 May 2010 13:52 - 21 May 2010 13:54 #369590 by mark1122
Replied by mark1122 on topic 1000 bottom end finally coming together
U must install the clutch basket before the cases go together.
Did u replace the clutch BASKET springs(not clutch springs)? This would be wise for a big block.the cases must be split to do it later.
Is this your big block motor? i asume so since u have a bearing cap and billit second.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 21 May 2010 13:54 by mark1122.
21 May 2010 17:59 #369658 by PLUMMEN
Replied by PLUMMEN on topic 1000 bottom end finally coming together
21 May 2010 20:59 #369706 by jordan
Replied by jordan on topic 1000 bottom end finally coming together
yessir, this is for the big block :) Yes, i have new clutch basket springs installed (could spin the old ones) and had the pins welded. Thanks for the help, i do have the cam chain on the crank, and the o-ring between the cases. I will make sure to attach the clutch basket first as i do not have it on yet. I cant wait to get this thing together. Now all i need is to build a stout head and get some cams/carbs (where the dollars really begin to add up :( )
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • mark1122
  • Keep twisting it
22 May 2010 04:50 - 22 May 2010 09:08 #369738 by mark1122
i may be able to put u in tough with some used RS38's that need a rebuild, if interested.
i would consider a cam chain guide . it is a small guide that goes over the cam chain and sprocket . this keeps the chain in place when u are installing the cams.
1 job i do find very tedious, is installing the cams at the proper timing. if u are not careful to keep tension on the cam chain at all times, the chain can become dislodged from the crank sprocket. this is a big PITA. u must do this every time u reshim the cams.sometimes it gets lodeged beside the sprocket and it seems like it is inplace,VERY FRUSTRATING(to me anyways)
i believe Schnitz sells them, for about $20.i dont see it listed any more. u could call them and ask about it. Has anyone ever tried 1 of theses. every time i install my cams , i wish i had 1.
did u get an oil pan gate?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 May 2010 09:08 by mark1122.
  • larrycavan
  • Visitor
22 May 2010 21:16 #370000 by larrycavan
Mark,
You have no idea how much I lauged when I read that. I know somebody that just did that [bolted the cases together with the clutch basket on the workbench] with a drag bike. They're used to Suzuki's so they didn't think anything about it... :laugh:
  • mark1122
  • Keep twisting it
23 May 2010 04:56 - 23 May 2010 04:57 #370060 by mark1122
Yah i can see that happening.
just like when u buy a new cabinet or something. u try to put it together , without the instructions, or the instructions are so bad u cant figure them out. in the end u put the thing together and take it apart a dozen times before u get it right.
Sometimes we don’t look forward far enough in our KZ manuals either. :laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 May 2010 04:57 by mark1122.
23 May 2010 14:08 #370229 by jordan
no i did not get an oil pan gate, would u recommend that i get one?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • mark1122
  • Keep twisting it
23 May 2010 15:27 #370271 by mark1122
That is a definite YES. When u launch the oil goes to the back, away from the pickup.
U CAN MAKE 1 YOURSELF.
just get a small hinge from the hardware store and mod it a bit. i screwed mine to the side of the oil filter housing. this way u dont need to drill a hole on the pan that can leak.
i reamed the oil drain hole on top a wee bit to, then modded the oil cup for more flow to prevent crank case pressure build up. (which could cause leaks.)
there is a pic of this mod in my project. pm me if interested.
B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
23 May 2010 15:40 #370280 by PLUMMEN
you could always put a mild topend on there and add the other stuff as your time and budget allow,just a thought
