Reconsidering revving problem-thoughts on this?
- Turtle
21 May 2010 16:56 #369636
by Turtle
1980 KZ 1000 A4 with 750 Zephyr swing arm and ZX-9 rear wheel
Replied by Turtle on topic Reconsidering revving problem-thoughts on this?
I am chasing a similar problem with my sons 1980 KZ1000 A4. when it's warmed up and you come to a stop the idle hangs around 3,000 rpm, then if I let the clutch out and put a load on it the rpm drops to normal and idles steady.
Mine misses or spits back through the exhaust and sometimes the intake. Is your doing this also?
Here is a video of mine, you can see the idle hang but not bad because it is not fully wamred up in this video:
s96.photobucket.com/albums/l188/T4Turtle...current=P1000402.flv
- polkat
- Thank you received: 1
22 May 2010 10:00 - 22 May 2010 10:02 #369796
by polkat
Replied by polkat on topic Reconsidering revving problem-thoughts on this?
No, I hadn't considered the throttle shaft bushings. They seemed tight, but I suppose it could be the problem. Turtle, yes, sometimes it will come down if I give it a load, or if I shut it off, then right back on again while it's still turning, but not always.
It only rarely spits back, which seems to me more like a misfire, but it's rare.
I have read somewhere that enrichening the pilot screws might help this but I haven't tried that yet. Opinions on that?
Last edit: 22 May 2010 10:02 by polkat.
