- Thank you received: 1
Reconsidering revving problem-thoughts on this?
- polkat
One poster (sorry, can't remember who) suggested a possible problem with the ignition advance mechanism...that it might be stuck or not returning. This advancer comes into play around the above rpm's...right? I checked it out and it is loose and does return, but it doesn't snap back as one might expect. Just slides back fairly quickly but not with the spring force expected.
So, I'm wondering if after 30 years, the springs might be streached or weak? Any opinions on this, or am I creating a problem in my head? Are these springs even still available? Thanks!
- Thank you received: 2098
Reinstall and test run.
Springs strong enough to close it at idle rpm should be serviceable.
Would also assure pilot circuits aren't too lean.
And repeat testing for air leaks.
- polkat
I'll check on the advancer in the morning. The pilot O rings are new, and the screws are set to 2 turns out from closed. Should I open them up some more?
Won't hurt to try. If it doesn't help calm the racing idle, return settings to default positions.
Seems most of the common vacuum leak sources have already been addressed. But might ultimately need to again resort to the WD40 spraying exercise.
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Motor Head
- Thank you received: 391
I think the pilot screws are air screws and you made the mixture leaner. I also think that the "cleaning" that was done was not sufficient. The air jets on the CV34 can easily clog and must be cleared. Note they are located under the slide diaphragms and continue on passageways down into the secondary main jet well and the pilot jet well.
So try to make sure that the Idle mixture screws are set correctly since turning them out sounds like adding air/ leaning the mixture, also double check the Air bleed orifice referred to by this other Poster.
- polkat
I don't think it's a carb problem. In fact, it does act just like a cable hang-up problem, but there's no hang-up. I have noticed that if, when it's holding a high rev, if I turn the kill switch on for just a second, just long enough for the engine to drop a bit in rpm, then turn it on again, the engine drops to normal idle.
This is what is leading me to believe it might be a problem with the advancer. If, when revving the engine, the advancer gets stuck open, would that cause the rpm's to stick up high?
- Motor Head
I remember you saying it would hang in RPM with the cable disconnected, have you held a timing light on it to see how much advance at RPM and smooth advance/ return?
Also don't these still have a throttle valve on a shaft? If so have you checked the small seals that go on each out board shaft end? A buddy of mine had this problem with a set of carbs on a Yammer XJ.
...might be a problem with the advancer. If, when revving the engine, the advancer gets stuck open, would that cause the rpm's to stick up high?
Yes. Could watch it with a timing light. Advancer should quickly close when throttle closed.
- polkat
I just came in from pulling the advancer. Didn't see a problem. It snaps back just fine from twisting it ahead with no spring slop. I took it apart anyway and cleaned it up and lubed it. Works fine, so I guess we're back to an air leak somewhere.
I rebuilt the top end recently. Could the head gasket need re-torquing? If that was letting air in wouldn't I hear blown gasket-like sounds? Runs strong otherwise. It's a mystery!!
- Motor Head
