Engine tick at idle
- Big_Wheel
Engine tick at idle
20 May 2010 19:44
Hello,
Ive read through a bunch of posts concerning a ticking coming from the engine during idle. Its too low of a frequency to be considered valves so Im thinking its the cam chain. The bike is a 1984 ZN750 so it has the auto tensioner. Im thinking of just putting the manual tensioner in it to see if it makes a dirrerence. What do you guys think?
Things to note:
-noise disappears at higher rpms and appears more prominent during colder starts.
-bike runs great (crisp throttle response, lots of power throughout the range, no flat spots, etc.)
Thanks,
Curtis
Things to note:
Thanks,
Curtis
- mjkawa
Re: Engine tick at idle
20 May 2010 20:36
Hey Big wheel, to my ear, a loose cam chain is much more like a rattle than a tick.
But it could be.
Just because it has a auto tensioner, doesnt mean that is working correctly. Maybe take it apart, and make sure that it is functioning.
Also, noise probably is drowned out by the engine noise at higher rpms.
just my .02
MJ
But it could be.
just my .02
MJ
82 KZ-1000-J
77 KZ650 B
77 KZ650 B
- bountyhunter
20 May 2010 21:45
small exhaust leak can sound like a click.
20 May 2010 21:58 - 20 May 2010 22:00
bountyhunter wrote:
After checking and gently snugging exhaust clamp nuts, could remove spark plug caps one at the time which might help determine which cylinder has the exhaust leak, as lack of combustion may reduce the ticking.
+1small exhaust leak can sound like a click.
Last edit: 20 May 2010 22:00 by Patton.
- Turtle
21 May 2010 16:59
+2
Exhaust leak may be the issue, and a cheap fix.
1980 KZ 1000 A4 with 750 Zephyr swing arm and ZX-9 rear wheel
- Motor Head
21 May 2010 17:15
I use 1/4" fuel line on my mechanics stethoscope, but just the hose to you ear will work really good to find a noise. Have you checked your valve clearence? How many miles is on it? You can replace the springs on the auto tensioner cheap.
- PLUMMEN
21 May 2010 17:56
synch your carbs
- TeK9iNe
- What did you do!?!
21 May 2010 18:07
PLUMMEN wrote:
and get a manual
It makes a huge difference to perform all of the necesary maintenence.
synch your carbs
and get a manual
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Big_Wheel
31 May 2010 12:02
Thanks everybody!
I have a service manual (both clymers and haynes) but a factory one would be perfect. I checked for exhaust leaks and there doesn't appear to be any. I have just installed the manual timing chain tensioner but I haven't thrown the carbs back in quite yet (Ill post an update in about an hour).
Some more background info:
-its got 36,000 kilometers on the odo.
-valve clearances within spec.
- PLUMMEN
31 May 2010 12:03
why did you use a manual tensioner?
- Old Man Rock
31 May 2010 13:09
"I have just installed the manual timing chain tensioner"...
Did it Ticky-Tick pre this installation?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TeK9iNe
31 May 2010 19:21
Big_Wheel wrote:
One thing to remember... the manual tentioner does need to be periodically tightened from time to time.
:laugh: Hence the manual part.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
