Quieter Exhaust Please
- Genros
My KZ900 (1060) motor has a vance hines exhaust.
1. The exhaust has no baffle and is to loud to daily drive to work etc.....(all hours of the night waking up neihbors)
2. Brake pedal clearence problems
Please recomend an exhaust that will be quieter and not compromise the performance if anything please improve performance. A working rear brake would be a plus too.
If possible im working on the cheap as i am thinking of selling the bike.
- otakar
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=364179
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
Guys,
2. Brake pedal clearance problems
Please recommend an exhaust that will be quieter and not compromise the performance if anything please improve performance. A working rear brake would be a plus too.
If possible i'm working on the cheap as i am thinking of selling the bike.
Pic might be helpful.
Baffles are available for V/H street model, which usually don't interfere with brake pedal function.
V/H sidewinder model (drag racing) requires brake pedal modification, and is designed for application on bikes with raked (extended) front ends to clear the front wheel/fender. And might afford less right-hand cornering clearance.
Edit:
bj (hocbj23) says, NO clearance problems cornering or otherwise. Footpegs drag before pipe does.
- kawsakiman
- Thank you received: 6
- hocbj23
- Visitor
