oil weight...
- larrycavan
Re: oil weight...
22 May 2010 17:55
PLUMMEN wrote:
If you ride without underwear, you can go longer between oil changes
...or is that just a myth???
otakar wrote:I buy my underwear at walmart in 3 packs,i buy my oil at napa autoparts! :laugh:It would not be a bad thing but it will rob you of power. Even Ford motors recommends 5W-20 in their Mustangs to increase power and fuel economy. If you run the lightest Shell Rotella-T you can find in your bike, It will give ALL the protection your bike will require without breaking the bank and destroying your power and economy. I run 10W-30 in my bikes and I think that most guys on this web sight will agree. It would not hurt anything if you add a few OZ of the new "Rislone with ZDDP" to your oil either. I buy my Rotella at Walmart in 2.5 Gallon buckets for about $23 when its on sale.
www.counterman.com/Article/73549/rislone...that_restores_z.aspx
- hocbj23
Re: oil weight...
22 May 2010 17:59
only thing u can go longer between is companionship if u ride without underwear.Pheww.BJ
- bountyhunter
Re: oil weight...
22 May 2010 20:42
larrycavan wrote:
PLUMMEN wrote:otakar wrote:For the record, the MSDS sheet on STP oil treatment confirms they also add "proprietary zinc compounds" to the tune of about 3% of total volume of their product. I called them and they confirmed it does raise oil ZDDP levels back up to original levels.It would not be a bad thing but it will rob you of power. Even Ford motors recommends 5W-20 in their Mustangs to increase power and fuel economy. If you run the lightest Shell Rotella-T you can find in your bike, It will give ALL the protection your bike will require without breaking the bank and destroying your power and economy. I run 10W-30 in my bikes and I think that most guys on this web sight will agree. It would not hurt anything if you add a few OZ of the new "Rislone with ZDDP" to your oil either. I buy my Rotella at Walmart in 2.5 Gallon buckets for about $23 when its on sale.
www.counterman.com/Article/73549/rislone...that_restores_z.aspx [img size=171]
- otakar
Re: oil weight...
22 May 2010 21:28 - 22 May 2010 21:39
Yes I do know that about STP, but it will also REALLY raise the viscosity of your oil. I like to run a very low viscosity oil. This is why I use the Lucas and Rislone additives, by themselves they are low viscosity. it is a known fact that lower viscosity fluids dissipate heat much better than high viscosity fluids.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 22 May 2010 21:39 by otakar.
- H1Vindicator
Last edit: 20 Feb 2013 20:15 by H1Vindicator.
- PLUMMEN
Re: oil weight...
23 May 2010 09:14
H1Vindicator wrote:
napas store brand oil is actually made by valvolinemtkawboy wrote:I don't know what oil you currently use, but the heavy duty motor oils are usually the cheapest - Shell Rotella-T, Chevron Delo & Valvoline Premium Blue are three that I know of. They typically have about the same ZDDP as motorcycle oils & reacing oils and are suitable for motorcycle use. The Chevron Delo was $9.99/gallon at O-Reillys recently. The Rotella is typically in the $12/gallon range. I've never seen the Valvoline anywhere.Apparently you prefer to pay more for your oil which is OK if you have the big bucks. Us poor retired people have to save it where we can
- otakar
Re: oil weight...
23 May 2010 09:43
Walmart has the 2.5Gal 15W-40 Rotella-t for $27 when it is not on sale. that is $2.70/Qt not on sale. I have bought it before for $22.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
