piston top cleaning
- otakar
Re: piston top cleaning
20 May 2010 12:11 - 18 Sep 2010 18:15
This is what I do. The best way to use the "spray" combustion chamber cleaner" is to;
1) heat up the engine to full operational temperature.
2) remove the spark plugs while hot.
3) Set pistons "about" half way between TDC and BDC.
4) Spray in the cleaner until it comes out the hole.
5) replace the spark plugs immediately.
6) wait until the engine cools down, or till next morning.
7) go for a VERY BRISK ride for about half an hour.
repeat step 1-7, 3-4 times.
Now you have a clean engine
9) use the Lucas in every tank.
10) step 1-7 may or may not be required about every 10,000 mi dependent on how much oil you burn. This is what my pistons looked like after more than 24,000 miles after doing steps 1-8.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Sep 2010 18:15 by otakar.
- bountyhunter
20 May 2010 21:52
My Kawi manual warns not to clean the piston tops installed in the engine because it forces the carbon crud down into the walls and into the rings.
20 May 2010 22:09 - 20 May 2010 22:09
bountyhunter wrote:
Same in FSM for '77~'79KZ1000 --- Bold Print.
Last edit: 20 May 2010 22:09 by Patton.
- otakar
21 May 2010 06:13
First of all they are talking about "physical or manual" cleaning, and the chamber cleaner dissolves the crud and varnish on top. The chamber cleaner is no different than using the cleaners on a regular basis in your gas. The chamber cleaner is also intended for use to "clean out" your rings.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
21 May 2010 10:17 - 21 May 2010 10:18
Maybe it's OK, I am reluctant to use dissolving cleaners that send crud into places I can't see or scrub because I don't know how much gunk hung up there.
Last edit: 21 May 2010 10:18 by bountyhunter.
- otakar
21 May 2010 11:00
that's totally up to you. This is what they are designed for and they work. I have been using them for years and they work great and I have never had a problem or a stuck ring. to each his own I guess.
Here is one by and for Yamaha
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
21 May 2010 14:49
BTW, guys: I looked up the MSDS sheet on that stuff and it's main ingredients are naptha, xylene and benzene. Benzene is one of the most toxic substances around, ao don't breathe the vapors or let it sit on your skin.
I am always looking for solvents that can cut burned carbon to use cleaning revolver cylinders but I pass on benzene compounds.:ohmy:
- kawsakiman
21 May 2010 15:35
like it has been said, water works real good for this.
ever change a blown head gasket on a car?
it steam cleans that cylinder.
if the head is off, just brush the shit off after spraying with intake air cleaner and shop vac out the chunks.
then change the oil which you were going to do anyway.
- otakar
21 May 2010 15:57
if you use this stuff in the way i outlined above, your exposure to this stuff will be virtually non existent.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- stonemaster
21 May 2010 16:14
doing my piston tops as we speak, pretty easy
this is the before side
this is the after
I used these tools
1. Valvoline Carbs Cleaner (its the most toxic)
2. a brass wire brush
3. homemade suction adapter for shop vac
spray small amounts of carb cleaner into brush and scrub, carbon breaks down to liquid and is sucked off.
of course this is if no head on motor.
this is the after
I used these tools
- bountyhunter
22 May 2010 11:30 - 22 May 2010 11:39
Carb cleaner (and non chlorinated brake cleaner) are mostly acetone which isn't nearly as toxic as benzene.
www.health-report.co.uk/benzene-toxic-chemical.htm
I use brake cleaner by the ton for gun cleaning. I used to be a car painter and I washed my hands in the stuff. Dries out your skin, but unless you sniff the stuff to get high, the risks are pretty low.
When I cleaned my piston tops I packed a paper towel "ring" around the cylinder wall gap and used a cut off popsicle stick to scrape the top of the piston. Then vacuumed the crud off. I sprayed some acetone on a shop rag to buff the tops. Was very easy and nothing ran down the sides.
Last edit: 22 May 2010 11:39 by bountyhunter.
22 May 2010 12:23
Can remember growing up in the early back woods years when the "parts washer" for most everything was a metal bucket half full of gasoline. :laugh:
