piston top cleaning
20 May 2010 10:16 #369254 by chrispysaki
piston top cleaning was created by chrispysaki
Can I use a wire brush to get the carbon off of the top of the pistons, or will it damage them?
Thanks!
20 May 2010 10:21 #369255 by timebomb33
Replied by timebomb33 on topic piston top cleaning
quickest and easiest way if there is a lot.the other option is to use gasket remover if its not completly baked on.when using a wire wheel dont concentrate in one area too long and be carefull around the ring lands
I THINK MY POWERBAND BROKE
20 May 2010 10:22 #369256 by BSKZ650
Replied by BSKZ650 on topic piston top cleaning
a wire brush is fine, I also would use some carb cleaner, it will help loosten the hard carbon, not knowing if you have the pistons off or how you are working on them, just be careful around the ring lands
77 ltd1000, current rider
76 kz900, just waiting
20 May 2010 10:23 #369259 by BSKZ650
dang it,, fingers wernt fast enough,,lol
20 May 2010 10:24 #369260 by timebomb33
got to be quick around here brother.
20 May 2010 11:12 - 18 Sep 2010 14:12 #369273 by otakar
Replied by otakar on topic piston top cleaning
Best and quickest way to clean them is while they are still in a running engine, just bu using combustion chamber cleaner.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 18 Sep 2010 14:12 by otakar.
20 May 2010 11:14 - 20 May 2010 11:15 #369274 by otakar
This is what you get. this piston was just wiped off with a rag.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 May 2010 11:15 by otakar.
20 May 2010 11:16 #369275 by otakar
This is what the inside of the head looked like after wiping it out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • stonemaster
  • Visitor
20 May 2010 11:34 #369280 by stonemaster
Replied by stonemaster on topic piston top cleaning
+1 on that using some today on mine
20 May 2010 11:39 #369283 by chrispysaki
Replied by chrispysaki on topic piston top cleaning
Wow, Okatar, can't argue with that! Where do you buy that combustion chamber cleaner?
20 May 2010 11:41 - 20 May 2010 11:46 #369287 by Patton
Replied by Patton on topic piston top cleaning
Besides the spray-can products used by spraying into carbs while engine's running, other products are just added to fuel supply.
PBBlaster sprayed or poured through spark plug holes into combustion chamber, and allowed to soak for awhile, supposedly allows the carbon buildup to be blasted out the exhaust when the engine is next run. Or perhaps sprayed into carbs on running engine until engine dies, let sit for awhile to soak inside combustion chambers, then crank and run engine.
Sometimes water mist is sprayed into carbs while engine's running, to reportedly help blow out the built up carbon.
Results from the Mopar product (spray-can?) are impressive. :cheer:
Wonder how the other products and water spray compare?:unsure:
Good Fortune! :)
Last edit: 20 May 2010 11:46 by Patton.
20 May 2010 11:57 - 20 May 2010 12:00 #369294 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationchrispysaki wrote:
I did a whole thread on this some time ago, I will try and find it and post a link. The one you see in the picture is from any Mopar dealer. Or you can buy it in different packaging on eBay from this guy. I bought a whole case because it was co cheap.
Here is one link, but I know there is another which I will try to find.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=357990
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 May 2010 12:00 by otakar.
