Clutch rivet question
- idkleine
19 May 2010 22:15 #369165
by idkleine
Clutch rivet question was created by idkleine
I am trying to find information about replacing the rivets and damper rubbers on the clutch of my 81' KZ650CSR. I have seen a thread about it here before but now that I'm looking for it I can't find it. I have access to a machine shop for one more month so I'm hoping to do the rivets myself. I removed the rivets because I just had to know if the rubber was ok and they are actually pretty decent although I would like to replace the anyways if they are obtainable. I probably should have left it alone. Also wondering if there is some way to replace the rivets with something more serviceable such as bolts. Any pointers would be awesome. Thanks
- timebomb33
- Thank you received: 10
20 May 2010 11:37 #369282
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Clutch rivet question
get in touch with A.P.E they may be able to help i use their spring and rivit kits for my drag motors (z1 or kz 1000) all the time or you can try M.T.C they also build spring and rivit kits as well. don't know whats available for the 650's myself but i do have a clutch for a 750 alcohol bike that has been done so someone is doing them.
- idkleine
03 Jun 2010 21:52 #373283
by idkleine
Replied by idkleine on topic Clutch rivet question
Checked with APE today and they can't do anything for me. I can make the rivets I suppose but the dampers I don't know about. If I could find the right materiel to make them out of I could make a punch. Anyone got any ideas on this? Are there any other common internal engine parts made out of rubber on any engine? I can't think of any at the moment other than shaft seals and stuff.
