new to forum/1981 Kaw 1000csr/ blowby question
- 1981jmotor
- shade tree mechanic
It does have oil on top of the fin on the front and back, not just the front like I indicated in my earlier post.
Maybe the caps were used on earlier KZ motors? Maybe I do not see the caps? WTF? David
1981 Kawasaki CSR 1000
First bike ever at 14 years old was 1969 Honda CL 175.
Bought a brand new Honda CM400T at 16 years old in 1979.
- 9am53
- homebrew, and some bbq
- Thank you received: 3
When you take the valve cover off these caps will come out, they are rubber and have aluminum on the outside to cover up the black rubber. As is the case here, you had no clue there was anything there and the leak managed to elude you, if you get the black ones you can see if oil is leaking past them. These get crusty as they age and leak like a sieve.
BTW, that is a pic of my motor BEFORE fixing the leaks.lol
www.z1enterprises.com/detail.aspx?ID=1883
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- mark1122
- Keep twisting it
- Thank you received: 109
if u suspect blowby, i would add venting , not remove it.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 1981jmotor
Now, I thought all engines has SOME blowby. IF, IF, IF my normal crankase breather below the carbs had become plugged for whatever reason, then that may cause excess internal engine crankcase pressure, pushing the oil/vapor out all these mystery places.
I will use the footpowder method to determine where the seepage is on top of my fins, and will let you know.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Thank you received: 2236
9am53, The hoses that I looped apparently are just EGR gases that are routed back to the airbox with a vac-controlled smog valve.
Actually, the flow is in the other direction - fresh air to the exhaust to promote burning of unburned hydrocarbons (fuel).
Ergo, I do not think that removing the smog valve, and connecting the hoses to each other affected the blowby.
Correct.
Possibly, but more likely loose bolts or dried up o-rings, seals and gaskets.
Clean the engine, re-torque the cam cover and head bolts, powder test, repair.
- 1981jmotor
BTW, I tried to attach pics from my computer HD, and it is not working. I do not have a Photobucket acct.
- 1981jmotor
- 1981jmotor
- 1981jmotor
- 1981jmotor
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
