Air Suction Valves
- BIGD
18 May 2010 10:36 #368762
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Air Suction Valves was created by BIGD
I have a U.S. model 1981 KZ1000M1 it is the only part of the world that has this system on the motorcycle, every other country that this bike was shipped to does not. I am hoping someone can tell me what was there for the rest of the bikes. I had a Canadian model many years ago and can not remember. It most likely did not have the air suction valves in the cylinder head cover, and was wondering if the left and right air suction covers had the opening on each that connected the hose to the air suction valve or was there just a flat cover on the cylinder head cover with no connection. And if the air suction valve covers still did have the connection but not the air suction system where did the hoses connect to from the top of the air suction covers. If a picture from my manual is needed please ask. My manual only shows the U.S. model and not the others without this system. Thanks Don
- Thank you received: 2098
18 May 2010 10:57 #368766
by Patton
Replied by Patton on topic Air Suction Valves
Others are just plain without air suction covers.
- hocbj23
- Visitor
18 May 2010 12:26 #368776
by hocbj23
Replied by hocbj23 on topic Air Suction Valves
x2
- TeK9iNe
- What did you do!?!
- Thank you received: 28
18 May 2010 13:45 #368789
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Air Suction Valves
X3
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- loudhvx
- Thank you received: 1616
18 May 2010 15:29 #368810
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Air Suction Valves
In the other countries, the head still had the ports, but the valve cover was plain. However, if I recall, the non-U.S. valve cover had little round tabs that stuck out a little bit at the gasket surface just enough to cover the ports in the head.
1981 KZ550 D1 gpz.
Other links.
