high compression
- rspector
Thanks
- PLUMMEN
- Thank you received: 104
- porchev914
- Thank you received: 19
FRANKEN Z!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Not sure where to look :huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
1) blowing starter clutchs:
Blowing meaning?... i.e. clutch gear itself breaking teeth, snapping in half etc....
Does "Blowing" occur after a certain time lapse indicating slow degradations or all is good then WHAM, gear busts...
2) Electric start, kick start or external starter?
3) Have you also been replacing the Needle bearings, rollers and Springs?
4) abnormal noises when starting or during normal engine running?
5) Possibly damper rubber clearances are off.
Best guess at this point, weak springs/roller travel free play...
This is out of my KZ900 Shop manual, maybe will help....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
Can u give us some more details on your exact issue.
cranking psi would be good to know here.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- rspector
Will the damper rubber cause catastrophic starter clutch problems? Because I will def check that , thanks for the info
- PLUMMEN
- mark1122
- Keep twisting it
i wonder if u are getting a kick back that destroys the clutch?
this doesn’t sounds like a starter problem, but i do wonder if it turns over too slow, if that could affect the clutch with kick back?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- hocbj23
- Visitor
- keith1
cranking psi is about 165. I have rebuilt one, needles springs rollers ect. When that one went it pushed the needles in enough to dent the back of the starter clutch. Its on its second now that I purchased off ebay (maybe the issue) but it looked fine. It seems like it just fails when your in mid crank and the engine fires. Now i'm getting the whiring noise of the starter still spinning after the engine starts(starter clutch not disengaging). It has the kick start, but I ca'nt kick the bike over myself. I should try the honda starter, i'm wondering if a weak starter can hurt the starter clutch?
you might very well be using the wrong size(thickness) damper....if your starter is good and the pins and rollers are good and everything is put together right,using the wrong size damper can kill the whole deal in short order....too thin and it wont engage right and if too thick, will drag the starter to an early death....
redlinecycle.com/Starter%20Clutch%20Tech.html
here is a link above to explain.....you should get that baby to start right.....g/l....keith
