kz1000 shift fork spring ?????/
- trab
13 May 2010 19:33 #367791
by trab
kz1000 shift fork spring ?????/ was created by trab
Hi, guys just wondering why are there 2 types of kz1000 shift fork springs, some have 3 coils and some 4 coils do they interchange? I would think theres got to be a reason
for 2 different types of springs, I'm having shifting problems and was wondering could be the issue.....Thanks........Trab
- timebomb33
- Thank you received: 10
14 May 2010 07:42 - 14 May 2010 07:42 #367862
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic kz1000 shift fork spring ?????/
it could be the problem the reason they went to the 4 coils was the 3 coil spring could weaken fairly quickly. and they do interchange
Last edit: 14 May 2010 07:42 by timebomb33.
- Jeff.Saunders
14 May 2010 09:14 #367883
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic kz1000 shift fork spring ?????/
timebomb33 wrote:
They DO NOT interchange.
If you install a 4 coil spring in the earlier Z1/KZ900 engines it WILL bind and you will not be able to shift.
If you install the 3 coil spring in the later bikes it might work, but the spring will be able to move around and you may have issues.
I have broken the 3-coil spring in the past - they do fail. But replace a 3-coil spring with a 3-coil spring.
Z1 Ent on Facebook,
- trab
16 May 2010 16:46 #368371
by trab
Replied by trab on topic kz1000 shift fork spring ?????/
Hey, thanks guys, I got the shifting problem fixed, i had the wrong shifter spring in it, changed from the 3 coil spring to the 4 coil spring took her out for a spin the gears, changed fine,again thanks for all your help......Trab
