deglazing clutch plates
- brianrae33
13 May 2010 18:11 #367756
by brianrae33
1982 kz1000ltd
deglazing clutch plates was created by brianrae33
so..do you deglaze the steel plates or the fibre plates??
1982 kz1000ltd
- PLUMMEN
- Thank you received: 104
13 May 2010 18:12 #367757
by PLUMMEN
Replied by PLUMMEN on topic deglazing clutch plates
throw the steel plates in a glass beading cabinet
- Thank you received: 2098
13 May 2010 18:18 #367759
by Patton
Replied by Patton on topic deglazing clutch plates
- otakar
13 May 2010 18:24 #367761
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic deglazing clutch plates
:huh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
13 May 2010 18:26 #367762
by PLUMMEN
glassbeading the steel plates helps oil stick to them better
- brianrae33
13 May 2010 18:48 #367772
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic deglazing clutch plates
once i've deglazed them do i soak both fibre and steel plates in oil overnight??
1982 kz1000ltd
- PLUMMEN
13 May 2010 18:51 #367773
by PLUMMEN
the steel plates dont need to be soaked,just dunk em and install.depending on how you clean them it wouldnt hurt to soak the fiber plates
