- Thank you received: 7
clutch springs
- toad
13 May 2010 11:26 #367665
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
clutch springs was created by toad
I believe I'm in need off new clutch springs and someone told me I could put an extra washer on the bolt until I get some.Does this really work and do I just add the washers to the backside of the 5 springs?It's a z1 thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- bountyhunter
- Thank you received: 337
13 May 2010 11:28 #367666
by bountyhunter
Replied by bountyhunter on topic clutch springs
That might help a little but as I recall the free length of those springs was about 1" so I am not sure a washer would do much to increase spring force.
- otakar
13 May 2010 11:32 - 13 May 2010 11:33 #367667
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic clutch springs
Why bother. You will have to do twice the work and use twice the oil to do all this work. You can have a new set of springs from Z1E in a matter of days. In the meantime just ride the way it is. When you replace the springs take the opportunity to clean and deglaze the clutch plates. New springs are less than $20 including shipping from Z1E.
www.z1enterprises.com/detail.aspx?ID=319
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 13 May 2010 11:33 by otakar.
- Motor Head
- Thank you received: 391
13 May 2010 12:45 #367681
by Motor Head
Replied by Motor Head on topic clutch springs
New springs the best idea, but I would also check the free play at the side cover adjustment as well as the cale at the lever.
- Thank you received: 2829
13 May 2010 13:13 #367689
by 650ed
Replied by 650ed on topic clutch springs
I wouldn't want to do the job twice especially considering that you'll need to buy the gasket twice (assuming you plan to do the job correctly). As stated by others, just order the springs (and gasket) and ride as is for a week. One other note; once you open up the clutch you should measure the friction plates to ensure that they are within service limits. Otherwise new springs won't fix a clutch slipping problem. Ed
- otakar
13 May 2010 13:18 #367690
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
how many miles are on the bike?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
- Thank you received: 104
13 May 2010 18:10 #367755
by PLUMMEN
Replied by PLUMMEN on topic clutch springs
what is the clutch doing? have you tried adjusting it?
- toad
15 May 2010 07:11 #368086
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic clutch springs
well I got a little anxious and tore the clutch plates out of the bike to find 4 cracked fiber plates,I got 4 more good ones from a buddy cleaned and deglazed all of them,reassembled,I even reused the old gasket and wow what a difference no slipping and no leaks iether.I still may order a whole clutch kit soon anyway but,this was a good temporary fix.thanks cheers.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- otakar
15 May 2010 08:24 - 15 May 2010 08:28 #368093
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Post some pictures of what you found cracked. I would be interested. Especially on a stock bike. If the clutch was overheating than it was slipping and the springs are still bad. as I have mentioned before in other posts. The springs go bad with time under compression.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 May 2010 08:28 by otakar.
