kz1000 shifting problem
- trab
12 May 2010 18:15 #367552
by trab
kz1000 shifting problem was created by trab
Hi, guys I'm having tranny problems, it up shifts ok but I can't get it to go back into first or neutral, even at a complete stop. the shifter feels real tight. I just finished a complete engine rebuild. ??? is it possible to
install the small forks wrong,does the shifter spring makes any different? thanks in advance for any advice............trab
- hocbj23
- Visitor
12 May 2010 19:11 #367567
by hocbj23
Replied by hocbj23 on topic kz1000 shifting problem
clutch adjusted properly? much easier to upshift and match rpms than downshift--ask any trucker.I would adjust the clutch before I worried about a shifter problem internally.bj
- MFolks
- Thank you received: 540
12 May 2010 19:17 #367570
by MFolks
Replied by MFolks on topic kz1000 shifting problem
Weight/grade/type of oil being used?
Best Oils To Use In Your Bike
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50. Here's several pages All About Oil justifying these conclusions.
The Recommended Synthetic Oils
5w-40 Delvac 1 Synthetic
5w-40 Mobil-1 SUV/Truck Synthetic
5w-40 AMSOil AMF Synthetic
10w-40 Golden Spectro Synthetic
10w-50 Motul 5100 Synthetic
10w-40 Mobil-1 Synthetic
15w-50 Mobil-1 MX4T Synthetic
The best synthetics are: (in no particular order)
Shell Rotella-T Synthetic 5w-40 (blue container, not white), gallon at Wal-Mart.
Mobil Delvac-1 5w-40 (grey container, not black), gallon at Petro stations, gallon at Farm and Fleet.
Mobil-1 SUV 5w-40, qt anywhere.
AMSOil AMF 10w-40 synthetic motorcycle oil, about qt.
Golden Spectro Supreme, (no price).
Motul 5100 Ester, (no price).
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
For temperatures below -40, I strongly recommend either Mobil-1 0w-30 or the Canadian Shell 0w-40 Rotella. At these temperatures, your car is your life. Using cheap or incorrect oil is risking your life.
For temperatures below -55c, -65f, stay home. Really.
The Recommended Petroleum Oils
Chevron Delo 400 15w-40
Delvac 1300 15w-40
Shell Rotella 15w-40
The best petroleum oils are: (in no particular order)
Chevron Delo 400 15w-40 (blue container) gallon at any auto parts store, gallons at Costco.
Mobil Delvac 1300 15w-40 (black container) gallon at any auto parts store, gallons at Sam's Club.
Shell Rotella-T 15w-40 (white container) gallon at Wall-Mart or any auto parts store, gallons at Sam's Club.
If you live in another country, you'll have to do a bit of research to decide on an oil. Generally, any oil certified for use in a late model Volks wagon or Mercedes turbo diesel is a good choice. Another good idea is to go to a truck stop and ask the truckers about brands. Rotella is marketed all over the world, but in other countries it's called Rotella or Rimola or Helix Ultra, and the formulation may be a bit different, depending on local climate and preferences. It will likely also be a lot more expensive than it is here.
Delvac 1300 15w-40
- trab
13 May 2010 02:01 #367612
by trab
Replied by trab on topic kz1000 shifting problem
Thanks guys, as for as oil i used rotella-t 5w-40, the clutch cable is properly adjusted, any other suggestion, again thanks in advance...........trab
