SOS WITH LOCKHART OIL COLER
- catahe
11 May 2010 15:27 #367288
by catahe
SOS WITH LOCKHART OIL COLER was created by catahe
hello riders could somebody please tell me where do i buy a lockhart oil cooler for my 1978 kz1000 z1r i already google it and i cant find it, the only place it shows was on ebay but its in sweden:angry: need your help asap thanks
- hocbj23
- Visitor
11 May 2010 15:38 #367292
by hocbj23
Replied by hocbj23 on topic SOS WITH LOCKHART OIL COLER
there are other options.satrab makes all sorts of oil coolers that will fit KZs. I am running one on my bike now.Also,u may be able to find one off an ELR bike.They also work as well.Good luck.BJ
- Thank you received: 2098
11 May 2010 16:42 - 11 May 2010 16:45 #367307
by Patton
Replied by Patton on topic SOS WITH LOCKHART OIL COLER
No eBay APP ID and/or Cert ID defined in Kunena configurationcatahe wrote:
Might also look at Lockhart oil coolers on ebay that aren't limited to a particular model.
For instance, this ebay listing shown here refers to Harley Sportster, but appears to be the same as I run on Z1 and KZ900. (See pics below.) This style Lockhart was popular, in black or chrome. And some owners also added a thermostat.
Am unaware of fitment limitations peculiar to Z1R due to its fairing or other parts.
If not already aware, replacement parts for the oem fitting under oil pressure switch at rear of motor under carbs must also be installed to allow connections for the oil lines to and from the cooler (on the large fours).
[Click on image to enlarge view.]
Last edit: 11 May 2010 16:45 by Patton.
- hocbj23
- Visitor
11 May 2010 16:48 #367308
by hocbj23
What Mr. Patton said.The oil cooler fitting for a GPZ1100 works just fine for my KZ,but may not work for other models.OldKawMan.com has a home-made cooler that may fit ur application as well.bj
- MFolks
- Thank you received: 540
11 May 2010 19:23 #367343
by MFolks
Replied by MFolks on topic SOS WITH LOCKHART OIL COLER
Look Here:
Oil Coolers & Accessories
www.batinc.net/mocal-central.htm
www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
12 May 2010 02:44 #367379
by Patton
No eBay APP ID and/or Cert ID defined in Kunena configurationThe one in Sweden looks like it would fill the bill and seems to have all the related parts.
