Intake clearance
- sbulla
- 1980 KZ1000 LTD
11 May 2010 08:02 #367209
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Intake clearance was created by sbulla
I know I'm probably getting a bit anal here but, which is better for an intake valve clearance .102mm or .152mm?
Numbers 2,3,4 all check at .127mm but number 1, with a 270 shim is .102mm and, with a 265 shim is .152mm.
I'd sure like to get them all the same. Wish they made a 267.5 shim.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Old Man Rock
- Thank you received: 225
11 May 2010 08:21 - 11 May 2010 08:25 #367212
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Intake clearance
"I know I'm probably getting a bit anal here"... Hey that's my title... :blush: You have no idea how anal I get... Ask Larry & Plumm... :laugh:
Due to performance build (compressions, cams and head) & heat, here's what I was taught...
Intakes @ .05 to .10mm
Exhaust @ .10 to .15mm
Due to heat, the exhaust clearance will shrink on you. Set between .1 - .15mm and shortly within running, she'll drop around the .10mm clearnace...
The intake will hold fairly steady so better at the lower clearance ~.10mm...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 11 May 2010 08:25 by Old Man Rock.
- otakar
11 May 2010 08:31 #367215
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Intake clearance
Because the gaps will not get bigger but will get smaller in time, when in doubt I always go with the next size larger shim. The only side effects will be that you will have .05mm less lift and the valves might "hiss' a bit more. But it is true, on the exhaust you do want to go bigger on the intakes it will not be that critical. If you have under-bucket shims than definitely go with the larger gap. It is a lot of work to go threw to change them again.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
- Thank you received: 337
11 May 2010 11:16 - 11 May 2010 11:24 #367237
by bountyhunter
Replied by bountyhunter on topic Intake clearance
sbulla wrote:
I'd never leave one at minimum clearance. A shade wide is no problem, too tight can burn a valve and ruin the valve seat. On mine, spec is .05 - .10 so I would think .102 would be OK but .15 is probably better.I know I'm probably getting a bit anal here but, which is better for an intake valve clearance .102mm or .152mm?
Sonny
Last edit: 11 May 2010 11:24 by bountyhunter.
- 9am53
- homebrew, and some bbq
11 May 2010 12:24 #367249
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic Intake clearance
Old Man Rock wrote:
hmm, so are you a tight end, or a wide reciever? :woohoo:
'84 GPz900r
'71 CB350
