Got spark but won't start
- btkz650
- Thank you received: 2098
- btkz650
Side-located pilot air screw in on airbox side of carb
Bottom-located pilot mixture screw is on engine side of carb.
Have heard of but am unfamilar with a manual slide carb having both type pilot screws.
[Click on image to enhance view.]
- btkz650
- rstnick
- Thank you received: 377
Here's an old post I found, but I know there was a recent one, just can't find it at the moment.
forums.kz650.info/index.php?PHPSESSID=f7...63193dd&topic=1484.0
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Here's a comparison between manual slide carbs.
Carb model with only bottom-located pilot mixture screw air screw has a pilot air jet "1" at entrance to pilot air passage.
Carb model with only side-located pilot air screw has no pilot air jet at "2" entrance to pilot air passage.
Wondering whether the rare carbs with both pilot screws have the pilot air jet "1" at entrance to pilot air passage, because no such jet appears on the diagram at kawasaki.com (posted earlier and again in following post).
Just guessing, but speculating that rare carb model with both side-located pilot air screw and bottom-located pilot mixture screw uses the pilot air screw function in place of the pilot air jet function.
Have seen scant tuning ideas about the rare carbs with both pilot screws. One suggested screwing the bottom located pilot mixture screw fully closed (removing it from the equation), and just using the side-located pilot air screw as if it was the only pilot screw. Another idea was to fine tune using both screws, but don't recall the sequence or method.
Perhaps detailed carb tuning information would be found in the FSM for the particular year and model on which such carbs appear.
- btkz650
