kz1000 engine casing
- rob220
09 May 2010 15:09 #366861
by rob220
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
kz1000 engine casing was created by rob220
could someone tell me what should I torque the 8 studs to in the bottom of the motor. I've got a 1075 with a welded crank and reinforced studs instead of the normal bolts. I didn't know if the studs get torqued the same as the bolts
1075kit
suzuki tl1000 rim
- PLUMMEN
- Thank you received: 104
09 May 2010 15:13 #366862
by PLUMMEN
Replied by PLUMMEN on topic kz1000 engine casing
i believe its 20 foot lbs for ape main cap studs,but i havent done one in a while
- rob220
09 May 2010 16:09 - 09 May 2010 16:10 #366883
by rob220
1075kit
suzuki tl1000 rim
Replied by rob220 on topic kz1000 engine casing
1075kit
suzuki tl1000 rim
Last edit: 09 May 2010 16:10 by rob220. Reason: too small
- rob220
09 May 2010 16:21 #366885
by rob220
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- rob220
09 May 2010 16:23 #366887
by rob220
1075kit
suzuki tl1000 rim
sorry using another cpu and diff programs and cant resize
1075kit
suzuki tl1000 rim
- rob220
09 May 2010 16:31 - 09 May 2010 16:35 #366891
by rob220
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
Last edit: 09 May 2010 16:35 by rob220. Reason: resize
