Backlash in transmission
  • gutter
  • gutter's Avatar Topic Author
09 May 2010 09:33
#366803
I was in the process of replacing my chain when I noticed that if I have 1st gear engaged, the primary drive sprocket has about a chain link worth of rotation in it.
How much is there suppose to be, if any?
Thanks!!
  • TexasKZ
  • TexasKZ's Avatar
Re: Backlash in transmission
10 May 2010 06:20
#366984
I'm sure that depends on the particular model you have, but what you have seems excessive.
For J - model (1000 cc)the standard backlash as measured at the primary to clutch gear interface is 0.03 - 0.10 mm. Max limit is 0.14 mm.
