crank case sealant?
- idkleine
crank case sealant?
08 May 2010 23:12
I'm about to mate the 2 halves of my kz650 engine and I'm wondering what my options are for sealant. To be honest I will probably be back in there in the next couple of years so I don't want anything to hardcore. 3bond is the best Ive read on other threads but I'm wondering about something easier to remove. I have a tube of permatex motoseal 1 grey and it says "for frequently dissasembled engines" But who knows what that means. I'm probably not gonna use it unless someone here recommends it. It really doesn't seem like anything special. My surfaces are in pretty good shape and are super clean. Any advice?
- Kraz1
Re: crank case sealant?
08 May 2010 23:32 - 08 May 2010 23:33
I have had success with 3 Bond 1211, and Permatex Ultra Gray.
Last edit: 08 May 2010 23:33 by Kraz1.
- bountyhunter
08 May 2010 23:54
Ditto, I think the 3-bond is more "permanent" than the permatex which is very easy to scrape off.
- idkleine
09 May 2010 18:30
Ok. The permatex might be the right thing for me. Ill just make sure the surfaces are REALLy clean. Another product I really like is Great Stuff. But I don't know if its appropriate for case halves. It seems a little thicker than most sealants so I would worry that it wouldn't squeeze out all the way. It is really "great stuff" though.
- z1kzonly
09 May 2010 19:03
There is also "gaska-cinch" or something like that.
It is a thin yellow liguid, like yama-bond.
I have had a pint can for over 20 years.
It has a sponge applicator on the lid.
Nice stuff
Nice stuff
- Kawboy74
09 May 2010 19:55
I have used the Loc-Tite #51531 anaerobic gasket eliminator flange sealant which is a toothpaste size tube for about $22.00 here. The nice thing about anaerobic sealants is that they do not start to dry until it has no air around it giving lots of working time and also unlike RTV products,you don't get blobs falling into passageways. This stuff is a purple colour and can be easily applied and being a thin consistancy is easy to tell when parts are covered. good luck David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- Old Man Rock
09 May 2010 20:03
Believe you answered your own question...
"3bond is the best Ive read on other threads"... Here as well as others have replied. To prevent oil leaks thus insure engine oil pressure to specification as well, ideally lubricating internal engine parts etc...
Why use anything else, doesn't make sense not to.
Just my 2 worthless cents...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
09 May 2010 21:44
3-bond is what the mechanics at the local Kawi/Yamaha dealer uses to seal cases. I asked.
