- Thank you received: 2
do I have to?
- stonemaster
- Visitor
- keith1
I have head off 73z1 for exhaust stud repair (PO rigged shitty). My ? is do I have to replace the cylinder block gasket as well? the reason i ask is that today I saw a film of oil where the cylinder block attaches. Nothing of note but that would indicate a broken seal possibly?? or would a re-torque be sufficient when the head is reattached?
did the jugs come up?....when i pulled my head i saw a little weepage....i reassembled and had a tiny bit on the first start-up, but its all good....just dont any cycling of the motor with head off.....if i had to bet, i would say you are all right.......g/l.....keith
- stonemaster
- Visitor
- Motor Head
- Thank you received: 391
- stonemaster
- Visitor
- Motor Head
- stonemaster
- Visitor
- PLUMMEN
- Thank you received: 104
- rt green
- csrjoe
- stonemaster
- Visitor
and I think keith s answer is da one,
thanx for your replies
big bore kit goin in next year , internals are fine for now. will update, Betty is some old school FAP material say what.
