Can't get my cylinder jugs off
- Jodyb17
Any tips for getting this sucker off?
I thought about putting a piece of wood block over the head studs and using two clamps, one on the front and back of the cylinder jugs. But I don't know if that might damage the studs or lower case.:dry:
1977 KZ 650 C
- bountyhunter
- Thank you received: 337
- keith1
- Thank you received: 2
I have tried prying a bit, but I am loathe to break a fin in this process.
on the big bikes i think there is a slot near number 4 on the lower perimeter where jugs meet the case.....edit...yup just checked there is one..try that yet?...hopefully yours has one also....g/l......
- Jodyb17
I managed to pry it loose using the clamps, the biggest screwdriver I could fit into the slot with a wrench on the handle. Whatever they used on the gasket worked well.
After I got the cylinders free from the gasket, getting them off was a supremely colossal bitch. I'm understating it there. Am I a wuss or these typically this tough to remove?:blink:
How is this done in the shop? Bike mechanics earn their money for damn sure.
I don't know how I am going to ever get them back on. I guess I'll tackle that later.
1977 KZ 650 C
- bountyhunter
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Once it's free at the base, it should not be hard to slide the cylinder off the pistons unless it's rusted or some other bizarre problem.
Agree with bountyhunter...once the jugs are free of the cases, they should slide up and off the pistons relatively easily.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jodyb17
Other than rust, does this indicate a problem? Engine turned over pretty easy with the kick starter.
I'll post pictures of my pistons and cylinder soon.
1977 KZ 650 C
- Jodyb17
1977 KZ 650 C
- Jodyb17
1977 KZ 650 C
