Under Bucket Shims
- kenskz1000
08 May 2010 09:50 #366445
by kenskz1000
Under Bucket Shims was created by kenskz1000
I need a 13mm shim that is smaller than 2.05. I have not found a source for any smaller and really dont want to pull head and disassemble to cut down 1 valve tip for clearance. Any help would be great. Motor is 1075 with Web cams
- bountyhunter
- Thank you received: 337
08 May 2010 10:11 #366451
by bountyhunter
Replied by bountyhunter on topic Under Bucket Shims
I think the reason they don't go any smaller is because they can crack if they get too thin.
- otakar
08 May 2010 11:12 - 08 May 2010 11:14 #366466
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Under Bucket Shims
2.05 is the thinnest made. If you require thinner, that means that you are way overdue for a valve job, or if you have just done one, you forgot to grind the valve stems.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 May 2010 11:14 by otakar.
- larrycavan
- Visitor
09 May 2010 07:25 - 09 May 2010 07:43 #366722
by larrycavan
Replied by larrycavan on topic Under Bucket Shims
Call Web Cams, they have some thinner shims available. I thin down to 185.
Problem is from the buckets most likely. Measure the thickness, they're either going to be .100" or abour .118". If they're aftermarket, purchased new in the last couple of years, they'll probably be the thicker ones.
Measure right on the button underneath when you check them.
Anyone ordering aftermarket cams should take note of this.
If you get cams that require shim on bottom & you're getting new buckets. Ask whoever your're getting them from to measure the thickness.
If you're not pulling the head for porting or valve work, see where you are in shim sizes. If your new buckets are going to be the thicker buckets, subtract 9 shim sizes from what you currently have.
If that puts you way down there close to 200 shim size, discuss getting the cams with a 1.080" base circle with the grinder. Most cams can be ground with reduced base circles. That would get you past the hurdle.
Eg:
Say you currently have 265 shims with stock buckets and stock cams. You're new buckets are in the .118" thickness range. Stock ones are .100". That's .018" less clearance you would have with new buckets if the cams are the same 1.110 base circle. That equals 9 shim sizes [roughly]
So from a 265, 9 shim sizes is 220.
IMO, most people with street motors waste their money when they buy cams that require S.O.B setup. There are so many good grinds available that can run S.O.T. and it pays other benefits as well.
1 - less chance of stripping out bolt holes at valve adjustment time because the cams stay in the motor.
2 - saves money on retainers
3- saves money on buckets
4- I've never seen lobes fail on cams that run S.O.T. adjustment.....
If a guy wants those long duration cams [260 @.050] with over .400 lift, there's only one way to go IMO...Cam Motion Z4 grind. They have .420" lift and KEEP SHIM ON TOP.
Larry C
Eg:
Larry C
Last edit: 09 May 2010 07:43 by larrycavan.
