Oil In Stator cover.
- fireguy55
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- JMKZHI
- Thank you received: 48
- Kawickrice
I don't know about the KZ400, but the 81 KZ650 doesn't.
True my 650 does not my 900 does. Time for a little research
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- hugo
- '92 Zephyr 750
- Thank you received: 71
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hocbj23
- Visitor
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
ALL KZ900/1000/1100s ZN1100 Zx1100A KZ1300 Zn1300 KZ750 ZX750A have oil in the stator area. You will have to get the manual for your particular bike and find out.
You will have to get the manual for your particular bike and find out. --- Yes, the FSM should have a detailed lubrication diagram showing all oil flows.
For example, the FSM lubrication diagram for large fours shows a few drops from the crankcase going through the crankcase bearing area on into the alternator section.
- loudhvx
- Thank you received: 1616
If I recall correctly, the oil just occasionally gets splashed in there on the 400 through the left crankshaft bearing which is a non-sealed ball type. There also may be a cutout in the wall to let the oil return to the crankcase.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
