Exhaust Question..
- Fozzie
07 May 2010 13:45 #366231
by Fozzie
1982 KZ1000J
Exhaust Question.. was created by Fozzie
So Ive fixed my carb problems but now I have an exhaust problem. When I give it throttle its fine, but when I release a white cloud of smoke comes out of the exhaust. Anyone have any clue why? How to fix this and should I be worried?
1982 KZ1000J
- otakar
07 May 2010 13:49 #366233
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Exhaust Question..
You are sucking in oil into the exhaust during deceleration. This is usually an indication of bad valve seals or piston rings.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- havakaw
- Thank you received: 27
07 May 2010 13:58 #366240
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Exhaust Question..
Make sure the oil is fresh,not full af gas.Have somebody ride behind you to watch for it.Does it get worse or better as you ride,and the warmer the engine gets.Check the level and plugs after 125 miles of use.That would give you a good indicator which cylinders are bad.A really bad valve seal will foul out a plug,and the fuel will wash down the cylinder,and ruin the rings.Been there.
'80 KZ 750 LTD-H
- otakar
07 May 2010 14:11 #366244
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The simplest way to tell if it's the rings is to put your finger over the crank case breather and see if you have a large difference in crank case pressure or vacuum. On these bikes you should have virtually neater pressure OR vacuum. The crank case should be almost neutral.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kawsakiman
- Thank you received: 6
07 May 2010 14:50 #366251
by kawsakiman
Replied by kawsakiman on topic Exhaust Question..
what bike?
please add it to your signature.
- Fozzie
07 May 2010 14:52 #366252
by Fozzie
1982 KZ1000J
Replied by Fozzie on topic Exhaust Question..
Jeez, if it aint one thing its another. So if it smokes more as the bike heats up its a bad valve seal, and the rings should be replaced? Ok, I'll run her for a bit and we'll see how bad she keeps smoking. Thanks fellas.
1982 KZ1000J
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 May 2010 15:04 #366258
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Exhaust Question..
Just dump that oil and put in a generic "dyno oil", 20W50.
Ride it good and hard.
Then check things.
GL.
Then check things.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Fozzie
07 May 2010 18:30 #366301
by Fozzie
1982 KZ1000J
I like the way you think Tek. New oil this evening and looks like the smoke cleared up some. Gonna ride like hell tommorrow. Thanks!
1982 KZ1000J
