kz gearbox compatability ???
- battymatty
04 Apr 2006 15:08 #36614
by battymatty
kz gearbox compatability ??? was created by battymatty
hello people, im now looking for a replacement gearbox for my kz1000(1980) ive found one of a 1980 z750 does anybody know if there the same, cheers mat
- steell
04 Apr 2006 16:21 #36647
by steell
Replied by steell on topic kz gearbox compatability ???
I have not tried to put a 750 trans in a 1000, but I seriously doubt that it would work.
You can compare part numbers at buykawasaki.com to see for sure.
- wireman
- Visitor
04 Apr 2006 17:40 #36683
by wireman
Replied by wireman on topic kz gearbox compatability ???
whats wrong with the transmission in the 1000?:whistle:
- wiredgeorge
05 Apr 2006 06:51 #36871
by wiredgeorge
Replied by wiredgeorge on topic kz gearbox compatability ???
Also, in 1980, there were differences between the transmissions/clutches in the KZ1000 models. Which model are you talking about? Can't say for sure on the KZ750 transmission. Someone else asked what was wrong with your transmission... perhaps there is some other solution if we know more particulars.
- battymatty
06 Apr 2006 00:13 #37153
by battymatty
Replied by battymatty on topic kz gearbox compatability ???
hello, my gearbox has a slipping third gear, i was only considering getting the replacement gearbox as its so cheap, im hoping that the problem is just a bent sector fork or something simple- i cant see any obious wear on main and layshaft pinions, anyway more tech info always appreciated - cheers mat
- fixer5000
- Thank you received: 5
06 Apr 2006 03:29 #37163
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic kz gearbox compatability ???
battymatty wrote:
i once had a similar issue with an old yamaha 350 2 stroker. i found the problem was the drive dogs on the side of the third gear were slightly worn into what id call a ramp instead of squared off like they were supposed to be. i took it apart and used a diamond file to make them all square again...problem solved no more poppin outta gear and hitting the redline !! steve
massachusetts
