Porting a KZ750 (4)
- chrispysaki
And are the gains even sufficient with a mild porting job to be worth the trouble?
Right now I'm running it with pods, 4-1 and gpz cams.
Thanks,
Chris
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- hocbj23
- Visitor
- T_Dub
- Thank you received: 25
Basically what you need to do is reduce resistance to flow, and making your ports smoother will do this. Also, some improper porting can cause big velocity differentials across a cross section, leading to poorer flow than you started with.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- larrycavan
- Visitor
I'm thinking about doing some mild porting to my intakes and exhausts and I know I should really have it done professionally with a flow bench and other equipment, but are there any safe guidelines for doing some basic, mild porting without making it worse?
Thanks,
Chris
Chris,
Decarbon the combustion chambers and inspect the intake valve seats to see if they're chipping away. I've seen several like that in the past year.
They chip away from the outside edge, just outside the 45 cut. Do this before you attempt to port the head. No use in putting hours into a head that needs the seats replaced.
- chrispysaki
- Ituen
- Rider
- Thank you received: 1
1982 KZ750 E
Kawasaki Rider
- larrycavan
- Visitor
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
